> I am building the 3 piece wing, adnd noticed a discrepency on the full> size wing rib plan. Obviously, the rib plan is for a 1 inch rib. What> are> you guys doing about the 1/4 inch discrepency?I built a 1 inch spar and had 1 inch holes in my ribs. It would appear that the> thrust load at the back of the spar (from the compression load) should> be transferred to the main spar. > I Don't follow you on this here.> Are you enlarging (lengthening) the two cross members to do this? or> does it matter?> > I am getting more confused than ever about the type of glue to use in> the wing structure. I like the T-88, but they sy it softens above> 150degrees. > Any comments would be appreciated.________________________________________________________________________________
Pietenpol-List: Wing plan dicrepency?
I am building the 3 piece wing, adnd noticed a discrepency on the fullsize wing rib plan. Obviously, the rib plan is for a 1 inch rib. Whatareyou guys doing about the 1/4 inch discrepency? It would appear that thethrust load at the back of the spar (from the compression load) shouldbe transferred to the main spar. Are you enlarging (lengthening) the two cross members to do this? ordoes it matter?I am getting more confused than ever about the type of glue to use inthe wing structure. I like the T-88, but they sy it softens above150degrees. Any comments would be appreciated.________________________________________________________________________________
Pietenpol-List: Re: Wing plan dicrepency?
Original Posted By: ehagness(at)mail.interconnect.net (Ernest Hagness)
Steve Eldredge wrote:> > > I am building the 3 piece wing, adnd noticed a discrepency on the full> > size wing rib plan. Obviously, the rib plan is for a 1 inch rib. What> > are> > you guys doing about the 1/4 inch discrepency?> > I built a 1 inch spar and had 1 inch holes in my ribs.> > It would appear that the> > thrust load at the back of the spar (from the compression load) should> > be transferred to the main spar.> >> I Don't follow you on this here.>>Sorry, If you used a 1 inch thick spar, you would need the one inchhole(s) to fit. I have the 3/4 inch thich spar, and the plans show a oneinch hole. I was wondering if it was necessary to alter braces one and 9(0 is the nose) to close the gap.> > Are you enlarging (lengthening) the two cross members to do this? or> > does it matter?> >> > I am getting more confused than ever about the type of glue to use in> > the wing structure. I like the T-88, but they sy it softens above> > 150degrees.> > Any comments would be appreciated.________________________________________________________________________________
> Steve Eldredge wrote:> > > > > I am building the 3 piece wing, adnd noticed a discrepency on the full> > > size wing rib plan. Obviously, the rib plan is for a 1 inch rib. What> > > are> > > you guys doing about the 1/4 inch discrepency?> > > > I built a 1 inch spar and had 1 inch holes in my ribs.> > > > It would appear that the> > > thrust load at the back of the spar (from the compression load) should> > > be transferred to the main spar.> > >> > I Don't follow you on this here.> >> >> Sorry, If you used a 1 inch thick spar, you would need the one inch> hole(s) to fit. I have the 3/4 inch thich spar, and the plans show a one> inch hole. I was wondering if it was necessary to alter braces one and 9> (0 is the nose) to close the gap.> > Got it. If I were building the 3/4" spar I would reposisition the center braces to make up the difference. IE leave the front face of the front spar and the rear face of the rear spare in the same place. Another option and one that I would probably opt for is making a 1" cap top and bottom to bring the dementions back to 1". Maybe there are other opinions.Stevee.BTW I used aerolite and Weldwood plastic resin. And probably would again.________________________________________________________________________________
Any opinion with the Tite Bond II water proof? The factory is Benjamin(something) Products. I had to boil the parts to get them unbonded.SaludosGary Gower>>> Steve Eldredge wrote:>> > >> > > I am building the 3 piece wing, adnd noticed a discrepency on the full>> > > size wing rib plan. Obviously, the rib plan is for a 1 inch rib. What>> > > are>> > > you guys doing about the 1/4 inch discrepency?>> > >> > I built a 1 inch spar and had 1 inch holes in my ribs.>> > >> > It would appear that the>> > > thrust load at the back of the spar (from the compression load) should>> > > be transferred to the main spar.>> > >>> > I Don't follow you on this here.>> >>> >>> Sorry, If you used a 1 inch thick spar, you would need the one inch>> hole(s) to fit. I have the 3/4 inch thich spar, and the plans show a one>> inch hole. I was wondering if it was necessary to alter braces one and 9>> (0 is the nose) to close the gap.>> >> >Got it. If I were building the 3/4" spar I would reposisition the >center braces to make up the difference. IE leave the front face of >the front spar and the rear face of the rear spare in the same place. > Another option and one that I would probably opt for is making a 1" >cap top and bottom to bring the dementions back to 1". Maybe there >are other opinions.>>Stevee.>>BTW I used aerolite and Weldwood plastic resin. And probably would >again.>>________________________________________________________________________________
Original Posted By:> JGreenlee(at)aol.com
Original Posted By: George Andrews
>Hold On!! Y'all are working too hard at this!Per Charlie Rubeck in his excellent rib building forums, all you have to dois glue a strip of 1/8" ply to each spar (1/2" wide by the heighth of thespar) where each rib would normally meet it. These fill up the gap to keepthe spars in the correct position relative to the cg and center of pressure,etc. At least this is what I am doing and it is no problem.Hope this helps.John________________________________________________________________________________
Pietenpol-List: Fwd: Wing plan dicrepency?
Original Posted By: JGreenlee(at)aol.com
> That is exactly what Ed Snyder & I did. His airplane has been flying for12 yrs & mine for10yrs. Mike---------------------Forwarded message:
Pietenpol-List:
Original Posted By: MBrusilow(at)aol.com
How do I subscribe to this list?John Kahn________________________________________________________________________________
Original Posted By: jkahn(at)dehavilland.ca (John Kahn)
