Pietenpol-List: jeep eng
so far this is what i have found out about the 134 L flathead jeep engine, asa possible substitute for the ford model A.3 1/8 bore4 3/8 stroke60 hp at 4000 rpm39 hp at 2000 rpm105 ft-lbs torque at 2000 rpmkind of sounds like a model a ford...And it does this on 33% less cubic inches!(sametorque, same hp,same rpm, 33% less cid to feed..) Probably becouse it achievesits power by better breathing. IE, bigger valves, Bigger ports in the heads,etc. And maybe a longer throw.Looking over one of these engines, I have also found that the block is about 1/3as large as the ford, so it should also be lighter.The only real problem that I can see is the length of the rear maim bearing. Sofar I have not seen a stripped block, and can find no body who will allow meto tear their jeep apart to look.A final note:The volkswagon engine runs from the front on a very narrow bearing, that was neverdesigned to swing anything like a propeller.I know that with the vw, "Great Planes" has modifyed the front bearing for greatersurface area, and does recommend this mod. Also they have recently come outwith a new bearing support that allows MUCH GREATER cid from their type 1 enginesthan they used to. For I think.........up to 125 hp....but i won't swearto that.I read recently about a fellow whe built a curtis hawlk at 80% scale. For powerhe installed a 350 HO chev engine in the plane that had a standard size (but4 bolt)rear main.His plan was to run the engine direct drive at 2500 revs, rather that go for 5000that the engine was designed for...There was no statement, ( or apparent concern)about sideways propeller loads.Lastly, (then I'll shut up) they say that one should never use any but a wood propon the vw, becouce of the weakness of the front main bearing. Apparently thewood prop does flex, and there-by does reduce the crosswise propeller loadson the weak front bearing.Some comments if any would be nice.BOBP.S. Can somebody recommend a good book for making homemade propellers ? The book : Propeller making for the Amature is out of printhttp://www.mailexcite.com________________________________________________________________________________
Pietenpol-List: Re: jeep eng
Original Posted By: scherer2(at)airmail.net (Glenn Scherer)
Subject: Pietenpol-List: Re: jeep eng>Oil Can,>Hey, send me your Snail Mail address and I will see about getting a copy of>"Propellor Making For The Amateur". I was walking by the copy machine atwork>today and my copy "fell in". Now I have this extra copy that you may aswell use.>>Send your P.O. address to seibert(at)swbell.net . I'll get it to you.>>Its too bad this book is out of print. It is really an excellent one.(Could>it be that Sensenich has bought up all the copies to keep it a secret?)>>On another note; the wife has consented to landing at Brodhead on the 25thon>our way to a family get together. Has anyone got any tips on landing there?Is>there a way to find a motel room/transportation for the night?>Regards,>Bob Seibert>RV-6 N691RV>Pietenpol still waiting for some landing gear parts>(Its too hot in Texas to weld very much!)>________________________________________________________________________________
Oil Can,Hey, send me your Snail Mail address and I will see about getting a copy of"Propellor Making For The Amateur". I was walking by the copy machine at worktoday and my copy "fell in". Now I have this extra copy that you may as well use.Send your P.O. address to seibert(at)swbell.net . I'll get it to you. Its too bad this book is out of print. It is really an excellent one. (Couldit be that Sensenich has bought up all the copies to keep it a secret?)On another note; the wife has consented to landing at Brodhead on the 25th onour way to a family get together. Has anyone got any tips on landing there? Isthere a way to find a motel room/transportation for the night? Regards,Bob SeibertRV-6 N691RVPietenpol still waiting for some landing gear parts(Its too hot in Texas to weld very much!)________________________________________________________________________________
Original Posted By: Seibert
Seibert,Where abouts in TX are you?I'm in Bowie.....John-----Original Message-----
John Greenlee wrote:> > Seibert,> > Where abouts in TX are you?> > I'm in Bowie.....> > JohnJohn,I'm south of Taylor about 2 miles (Northeast of Austin about 20).We have a grass strip here called "Macho Grande". It is XS41 and it is at 30deg 32.31 min North, 97 deg 25.17 min West. I do not know if it is on thelatest sectional. We got it done over a year ago and it takes a long time toget the NOAA to get the updated info on a map. (Think about that next time youare scud running and watching for towers!)We currently have 2 experimentals flying here and 4 under construction. (Oneis a Piet)If you are in the area some time, give me a call at 512-865-8918 or drop inout of the sky.Regards,Bob Seibert________________________________________________________________________________
