Pietenpol-List: NX FAA Rule
Sec. 45.22 Exhibition, antique, and other aircraft: Special rules. (a) When display of aircraft nationality and registration marks in accordance with Secs. 45.21 and 45.23 through 45.33 would beinconsistent with exhibition of that aircraft, a U.S.-registered aircraft may beoperated without displaying those marks anywhere on the aircraft if: (1) It is operated for the purpose of exhibition, including a motion picture or television production, or an airshow; (2) Except for practice and test fights necessary for exhibitionpurposes, it is operated only at the location of the exhibition, between theexhibition locations, and between those locations and the base of operations ofthe aircraft; and (3) For each flight in the United States: (i) It is operated with the prior approval of the Flight StandardsDistrict Office, in the case of a flight within the lateral boundaries of thesurface areas of Class B, Class C, Class D, or Class E airspace designated forthe takeoff airport, or within 4.4 nautical miles of that airport if it iswithin Class G airspace; or (ii) It is operated under a flight plan filed under either Sec.91.153 or Sec. 91.169 of this chapter describing the marks it displays, in thecase of any other flight. (b)ffff,0000,0000 A small U.S.-registeredaircraft built at least 30 years ago or a U.S.- registered aircraft for which an experimental certificate has beenissued under Sec. 21.191(d) or 21.191(g) for operation as an exhibitionaircraft or as an 0000,0000,ffffamateur-builtaircraft and which has the same external configuration as an aircraft built at least 30 yearsagoffff,0000,0000 may be operated withoutdisplaying marks in accordance with Secs. 45.21 and 45.23 through 45.33 if: (1) It displays in accordance with Sec. 45.21(c) marks at least 2inches high on each side of the fuselage or vertical tail surface consistingof the Roman capital letter "N" followed by: (i) The U.S. registration number of the aircraft; or (ii) The symbol appropriate to the airworthiness certificate of the aircraft ("C", standard; "R", restricted; "L", limited; or0000,0000,8080"X", experimental) followed by the U.S. registration number of the aircraft; and (2) It displays no other mark that begins with the letter "N"anywhere on the aircraft, unless it is the same mark that is displayed underparagraph (b)(1) of this section. (c) No person may operate an aircraft under paragraph (a) or (b) ofthis section-- (1) In an ADIZ or DEWIZ described in Part 99 of this chapter unlessit temporarily bears marks in accordance with Secs. 45.21 and 45.23through 45.33; (2) In a foreign country unless that country consents to thatoperation; or (3) In any operation conducted under Part 121, 127, 133, 135, or 137of this chapter. (d) If, due to the configuration of an aircraft, it is impossible fora person to mark it in accordance with Secs. 45.21 and 45.23 through45.33, he may apply to the Administrator for a different marking procedure. [Doc. No. 8093, Amdt. 45-5, 33 FR 450, Jan. 12, 1968, as amended byAmdt. 45-13, 46 FR 48603, Oct. 1, 1981; Amdt. 45-19, 54 FR 39291, Sept. 25,1989; Amdt. 45-18, 54 FR 34330, Aug. 18, 1989; Amdt. 45-21, 56 FR 65653, Dec.17, 1991] Sec. 45.23 Display of marks; general. (a) Each operator of an aircraft shall display on that aircraftmarks consisting of the Roman capital letter "N" (denoting United States registration) followed by the registration number of the aircraft.Each suffix letter used in the marks displayed must also be a Roman capital letter. (b) When marks that include only the Roman capital letter "N" andthe registration number are displayed on limited or restricted categoryaircraft or experimental or provisionally certificated aircraft, the operatorshall also display on that aircraft near each entrance to the cabin orcockpit, in letters not less than 2 inches nor more than 6 inches in height, thewords "limited," "restricted," "experimental," or "provisionalairworthiness," as the case may be. [Doc. No. 8093, Amdt. 45-5, 33 FR 450, Jan. 12, 1968, as amended byAmdt. 45- 9, 42 FR 41102, Aug. 15, 1977] Sec. 45.25 Location of marks on fixed-wing aircraft. (a) The operator of a fixed-wing aircraft shall display the requiredmarks on either the vertical tail surfaces or the sides of the fuselage,except as provided in Sec. 45.29(f). (b) The marks required by paragraph (a) of this section shall bedisplayed as follows: (1) If displayed on the vertical tail surfaces, horizontally on both surfaces, horizontally on both surfaces of a single vertical tail or onthe outer surfaces of a multivertical tail. However, on aircraft on whichmarks at least 3 inches high may be displayed in accordance with Sec.45.29(b)(1), the marks may be displayed vertically on the vertical tail surfaces. (2) If displayed on the fuselage surfaces, horizontally on both sidesof the fuselage between the trailing edge of the wing and the leading edgeof the horizontal stabilizer. However, if engine pods or otherappurtenances are located in this area and are an integral part of the fuselage sidesurfaces, the operator may place the marks on those pods or appurtenances. [Amdt. 45-9, 42 FR 41102, Aug. 15, 1977]________________________________________________________________________________
Pietenpol-List: Re: NX FAA Rule
Way to go Mike!Thanks again, for specific and delightfully useful information.Best Regards,WarrenMichael D Cuy wrote:> PART 45--IDENTIFICATION AND REGISTRATION MARKING>> Subpart A--General>> Sec. 45.22 Exhibition, antique, and other aircraft: Special rules.>> (a) When display of aircraft nationality and registration marks in> accordance with Secs. 45.21 and 45.23 through 45.33 would be inconsistent> with exhibition of that aircraft, a U.S.-registered aircraft may be operated> without displaying those marks anywhere on the aircraft if:> (1) It is operated for the purpose of exhibition, including a motion> picture or television production, or an airshow;> (2) Except for practice and test fights necessary for exhibition purposes,> it is operated only at the location of the exhibition, between the exhibition> locations, and between those locations and the base of operations of the> aircraft; and> (3) For each flight in the United States:> (i) It is operated with the prior approval of the Flight Standards District> Office, in the case of a flight within the lateral boundaries of the surface> areas of Class B, Class C, Class D, or Class E airspace designated for the> takeoff airport, or within 4.4 nautical miles of that airport if it is within> Class G airspace; or> (ii) It is operated under a flight plan filed under either Sec. 91.153 or> Sec. 91.169 of this chapter describing the marks it displays, in the case of> any other flight.> (b) A small U.S.-registered aircraft built at least 30 years ago or a U.S.-> registered aircraft for which an experimental certificate has been issued> under Sec. 21.191(d) or 21.191(g) for operation as an exhibition aircraft or> as an amateur-built aircraft and which has the same external configuration as> an aircraft built at least 30 years ago may be operated without displaying> marks in accordance with Secs. 45.21 and 45.23 through 45.33 if:> (1) It displays in accordance with Sec. 45.21(c) marks at least 2 inches> high on each side of the fuselage or vertical tail surface consisting of the> Roman capital letter "N" followed by:> (i) The U.S. registration number of the aircraft; or> (ii) The symbol appropriate to the airworthiness certificate of the> aircraft ("C", standard; "R", restricted; "L", limited; or "X", experimental)> followed by the U.S. registration number of the aircraft; and> (2) It displays no other mark that begins with the letter "N" anywhere on> the aircraft, unless it is the same mark that is displayed under paragraph> (b)(1) of this section.> (c) No person may operate an aircraft under paragraph (a) or (b) of this> section--> (1) In an ADIZ or DEWIZ described in Part 99 of this chapter unless it> temporarily bears marks in accordance with Secs. 45.21 and 45.23 through> 45.33;> (2) In a foreign country unless that country consents to that operation; or> (3) In any operation conducted under Part 121, 127, 133, 135, or 137 of> this chapter.> (d) If, due to the configuration of an aircraft, it is impossible for a> person to mark it in accordance with Secs. 45.21 and 45.23 through 45.33, he> may apply to the Administrator for a different marking procedure.>> [Doc. No. 8093, Amdt. 45-5, 33 FR 450, Jan. 12, 1968, as amended by Amdt.> 45-13, 46 FR 48603, Oct. 1, 1981; Amdt. 45-19, 54 FR 39291, Sept. 25, 1989;> Amdt. 45-18, 54 FR 34330, Aug. 18, 1989; Amdt. 45-21, 56 FR 65653, Dec. 17,> 1991]>> Sec. 45.23 Display of marks; general.>> (a) Each operator of an aircraft shall display on that aircraft marks> consisting of the Roman capital letter "N" (denoting United States> registration) followed by the registration number of the aircraft. Each> suffix letter used in the marks displayed must also be a Roman capital> letter.> (b) When marks that include only the Roman capital letter "N" and the> registration number are displayed on limited or restricted category aircraft> or experimental or provisionally certificated aircraft, the operator shall> also display on that aircraft near each entrance to the cabin or cockpit, in> letters not less than 2 inches nor more than 6 inches in height, the words> "limited," "restricted," "experimental," or "provisional airworthiness," as> the case may be.>> [Doc. No. 8093, Amdt. 45-5, 33 FR 450, Jan. 12, 1968, as amended by Amdt. 45-> 9, 42 FR 41102, Aug. 15, 1977]>> Sec. 45.25 Location of marks on fixed-wing aircraft.>> (a) The operator of a fixed-wing aircraft shall display the required marks> on either the vertical tail surfaces or the sides of the fuselage, except as> provided in Sec. 45.29(f).> (b) The marks required by paragraph (a) of this section shall be displayed> as follows:> (1) If displayed on the vertical tail surfaces, horizontally on both> surfaces, horizontally on both surfaces of a single vertical tail or on the> outer surfaces of a multivertical tail. However, on aircraft on which marks> at least 3 inches high may be displayed in accordance with Sec. 45.29(b)(1),> the marks may be displayed vertically on the vertical tail surfaces.> (2) If displayed on the fuselage surfaces, horizontally on both sides of> the fuselage between the trailing edge of the wing and the leading edge of> the horizontal stabilizer. However, if engine pods or other appurtenances are> located in this area and are an integral part of the fuselage side surfaces,> the operator may place the marks on those pods or appurtenances.>> [Amdt. 45-9, 42 FR 41102, Aug. 15, 1977]________________________________________________________________________________
>Way to go Mike!>Thanks again, for specific and delightfully useful information.>Best Regards,>WarrenYou are quite welcome !! Actually you guys might want to printthese FAR's out because your inspector might not be aware of thisallowance in the rules. My inspector was just a great guy- the bossof the Clev. FAA MIDO office and he wasn't aware of this rule untilI showed him my copy. No questions then !Mike C. ________________________________________________________________________________
