> VW Info
> VW Info
Original Posted By:> Andrew.Pietenpol(at)stpaul.com
I wont even pretend to know what I'm talking about, But...VW engine with psru, 65 hp 65hpx5252/2330rpm=146.5 ft-lbs C-65 engine direct drive 65 hpx5252/2400rpm=142 ft-lbsDoes this mean that the limiting factor of the 65 hp volkswagon engine with psru attached is cooling, or am i missing something about torque? I assume that in this situation both would use a nearly equal propeller.ocb>From steve(at)byu.edu Thu Jan 7 05:03:05 1999>Received: from adena.byu.edu ("port 1074"@adena.byu.edu [128.187.22.180])> by EMAIL1.BYU.EDU (PMDF V5.2-29 #31181)> with ESMTP id for oilcanbob(at)hotmail.com;>Date: Thu, 07 Jan 1999 08:01:37 -0500>From: Michael D Cuy >Subject: VW Info>Sender: Maiser(at)adena.byu.edu>To: Pietenpol Discussion >Errors-to: Steve(at)byu.edu>Reply-to: Pietenpol Discussion >Message-id: >MIME-version: 1.0>X-Mailer: QUALCOMM Windows Eudora Pro Version 4.1 (via Mercury MTS v1.44 (NDS))> (via Mercury MTS v1.44 (NDS))>Comments: Originally To: "Pietenpol Discussion" >X-Listname: >>> Subj: VW Engines> Date: Fri, Jul 24, 1998 11:57 AM EDT
