Original Posted By: "Mr. Carmen A. Natalie"
For those of you who want to wade through part 43:http://www.faa.gov/avr/AFS/FARS/far-43.txtI believe that you may do the 'conditional inspection' (annual) only ifyou are the builder of the aircraft and applied for and possess arepairman's certificate for it (required for each aircraft you build andis specific to that aircraft). Otherwise, you can work on it all youwant, but the annual must be performed by an A&P or IA. I'm not as sureabout the engine stuff, though.-Carmen________________________________________________________________________________
