Pietenpol-List: Corvair Cooling
To Domenic BellissimoDomenic:I was reviewing the pictures of your Piet on Richard DeCosta's website and noticed that you're using forced air coolingfor your corvair engine. How has that worked out for you and have you takenany temperature readings? Beautiful work, by the way. Also, do you haveany kind of estimate as to how much horsepower you are developing - that isa 110 engine isn't it?Mark BoyntonPhoenix, AZ________________________________________________________________________________
Pietenpol-List: Fwd: Corvair Cooling
To Domenic Bellisimo:Hi Domenic:You may have missed my original message (see below). Anyway, could youcomment. Thanks.Mark BoyntonPhownix, AZ ________________________________________________________________________________
Original Posted By:> mboynton(at)excite.com
To Domenic Bellissimo:You may have missed this message I sent to you (see below). Could youreview it and comment. Thanks.Mark BoyntonPhoenix, AZ
Pietenpol-List: Re: RE: Fwd: Corvair Cooling
Domenic:Good stuff. Keep us posted on how the temperatures work out. Hope itscool.Mark BoyntonPhoenix, AZ> Hi Mark,> > Thats a good observation. yes it is forced air cooling. I wanted toremove> the fan and twisted 90 degree fan belt. I know it may only have been a> problem with the turbo-version (belts would fly off) but I still wantedto> explore taking it off. I replaced the whole fan assembly with a 1 inch> aluminum plate which I machine cooling fins on. I placed a 1 inch borderall> around the aluminum stock for the screws. The thickness at the screws was> 0.5 inches. This realy helps to stiffen the engine. As you know thecorvair> engine would expand and contract and also move around a bit. This mayhave> been the cause of oil leaks in these engines, especially with the stamped> head and oil covers. I also replaced the head covers and oil cover withones> I purchased from Clarks' Corvair Parts. The oil pan is also 0.5 inchesthick> which helps to stiffen the engine. No oil leaks so far.> Now to answer your question: How has it worked out. well so far inground> tests in this cold weather ...no problem. I plan to have the first flight> this April, at least thats when I'm puting on the insurance. I eventually> plan to put a six position thermal computer at all the spark plugs to> monitor the temperature in flight. i'll keep you posted but have no dataas> yet. Jack Watson haas the same configuration and has been running it onthe> ground for the last 5 years (no first flight as yet) and he has not> experienced any heat related problems. He has run his in the summer. Just> over the VW starter that I am using I have an air inlet for cooling thefins> on my top cover. It dumps toward the back which helps to cool my Chev.Spint> alternator. The center is separated by internal baffles like the regular> continental forced air cooling method.> Horse Power?:110 H.P.: Don't know exactly unless I test it with somescales,> but estimate graphically about 83.5 H.P. at 2800 RPM at sea level. Maybe> sometime this summer I'll set up a test with an Engineer friend of mine.If> I do I'll certainly post it.> I'm glad you liked my photo's. Thanks to Richard he posted them for allto> see. Some friends here said they could access his site but could notaccess> my photo's for some unknown reason.> ----------
Pietenpol-List: Re: Fwd: Corvair Cooling
Hi Peter:That's too bad about Vertical Systems. I'm afraid I'm stumped about what todo. Does anybody out there know what happened to the company VerticalSystems. They're the ones who marketed the plans for converting the Corvairengine to use the Rinker propeller speed reduction unit. They were activeon the web as late as October of last year, but seem to have disappearedsince then. Thanks for the hint on the Aerolite, Peter.Mark BoyntonPhoenix, AZ> Hi Mark,> > Still no progress in contacting vertical systems. My e-mail bounced backas > you described and directory assistance in S.B. drew a blank. Sounds like> they have evaporated. Any ideas?> > As for the adhesive for the wing ribs. It seems that I recall hearingfrom a > number of people who are using titebond in their Pietenpol construction.I > have no question that its better than anything that was available in 1929.> For myself, I'm using Aerolite on the wing ribs. It is cheap and adelight > to use. If you haven't seen or used it, it comes as a powder and a liquid> catalyst. You apply the catalyst to one piece and the glue (mixed with > water) to the other. The nice thing is that you can mix the powder with > water in a plastic container and keep it for a few weeks in therefrigerator, > using it only as it is needed. There's no waste as there is with T-88,and > its shelf life (as a powder) is eternal. You don't have to rush a job > because your charge of epoxy is kicking its catalytic process in themixing > container (like T-88). It cleans up with soap and water and doesn't cause> problems if you get a bit on your skin or clothing. It also dries quite > rapidly if you use a thicker mix (although this seems to possibly reduceits > strength). Aerolite would be inappropriate for bonding larger surfaces,but > its perfect for wing ribs.> > I bought the $24 kit from AS&S, and after finishing my ribs the amount > consumed is almost imperceptable in the package. Aerolite has beenmaligned > recently in the homebuilt aircraft community, but it has a long history of> performing well on wooden aircraft. > > --Peter________________________________________________________________________________
> Corvair Cooling
Original Posted By: "mail.execpc.com"
> Message-ID: > > To Domenic Bellissimo> > Domenic:> > I was reviewing the pictures of your Piet on > Richard DeCosta's website and noticed that you're using forced aircooling> for your corvair engine. How has that worked out for you and have youtaken> any temperature readings? Beautiful work, by the way. Also, do you have> any kind of estimate as to how much horsepower you are developing - thatis> a 110 engine isn't it?> > Mark Boynton> Phoenix, AZ> > > > > _______________________________________________________________________________________________________________________________________
> Corvair Cooling
> > To Domenic Bellisimo:> > Hi Domenic:> > You may have missed my original message (see below). Anyway, could you> comment. Thanks.> > Mark Boynton> Phoenix, AZ> >
> > Corvair Cooling
> > Message-ID: > >> > To Domenic Bellissimo> >> > Domenic:> >> > I was reviewing the pictures of your Piet on> > Richard DeCosta's website and noticed that you're using forced air> cooling> > for your corvair engine. How has that worked out for you and have you> taken> > any temperature readings? Beautiful work, by the way. Also, do youhave> > any kind of estimate as to how much horsepower you are developing -that> is> > a 110 engine isn't it?> >> > Mark Boynton> > Phoenix, AZ> >> >> >> >> > _______________________________________________________> > > > > > _______________________________________________________________________________________________________________________________________
