Pietenpol-List: TIG and Aileron Gap
TIG and Aileron Gap
Original Posted By: Bill Talbert
Subject: TIG and Aileron Gap All the welds in my Piet are TIG welded then normalized. (brought to a dull cherry color with a torch in a larger area, and allowed to air cool in still air) Didn't know this till' I had the entire engine mount primed, painted and mounted !!! Guess what ?? It came off, got stripped, and each joint normalized with a torch. Good advice coming down the pipe from you welders out there. Earl Myer's Sky Scout incorporates an aluminum 6 foot piano hinge on his ailerons. An excellent gap seal AND hinge arragement. Not the cheapest stuff to buy, but you will never have to fuss with gap seals again. How much wood to shave off the loins to accept the hinge ? I just mounted it flush with the aileron spars and flush with the top of the ribs.....so having a wood trailing edge I just sandedthat down to match the rest of the wing trailing edge lines. Mike C.________________________________________________________________________________
All the welds in my Piet are TIG welded then normalized.(brought to a dull cherry color with a torch in a larger area,and allowed to air cool in still air) Didn't know this till' I hadthe entire engine mount primed, painted and mounted !!!Guess what ?? It came off, got stripped, and each jointnormalized with a torch. Good advice coming down the pipefrom you welders out there. Earl Myer's Sky Scout incorporates an aluminum 6 footpiano hinge on his ailerons. An excellent gap seal AND hingearragement. Not the cheapest stuff to buy, but you will neverhave to fuss with gap seals again. How much wood to shave off the loins to accept the hinge ?I just mounted it flush with the aileron spars and flush with thetop of the ribs.....so having a wood trailing edge I just sanded thatdown to match the rest of the wing trailing edge lines. Mike C. All the welds in my Piet are TIG welded then normalized.(brought to a dull cherry color with a torch in a larger area,and allowed to air cool in still air) Didn't know this till' Ihadthe entire engine mount primed, painted and mounted !!!Guess what ?? It came off, got stripped, and each jointnormalized with a torch. Good advice coming down the pipefrom you welders out there. Earl Myer's Sky Scout incorporates an aluminum 6footpiano hinge on his ailerons. An excellent gap seal ANDhingearragement. Not the cheapest stuff to buy, but you willneverhave to fuss with gap seals again. How much wood to shave off the loins to accept the hinge ?I just mounted it flush with the aileron spars and flush with thetop of the ribs.....so having a wood trailing edge I just sandedthatdown to match the rest of the wing trailing edge lines. Mike C. ________________________________________________________________________________
Pietenpol-List: Re: TIG and Aileron Gap
Original Posted By: Michael Cuy
The Aileron Hinge/Gap seal drawing is on it's way to Richard for postingon the website. I need to hear from a fella named"oilcan" atallaire(at)raex.com wheel/spoke info......Earl Myers -----Original Message-----
Original Posted By: David Swagler
> Earl Myer's Sky Scout incorporates an aluminum 6 foot>piano hinge on his ailerons. An excellent gap seal AND hinge>arragement. Not the cheapest stuff to buy, but you will never>have to fuss with gap seals again. >Just a comment that I remembered about piano hinges:Last year (in the self regulating) anual inspection the local owners of theTeman Monofly decided to change the piano hinge with the hinge sidedownside, the intention was to smooth the airflow in the wing (plain"cleaning") to see if it will improve the cruise... There was no safetydiference in putting the hinge facing down or up, the travel of the alerionswas the same...The problem was that there was LESS alerion response of the plane! It wasnothing unsafe at all, only it tooked a little longer to response and alittle more travel (only the pilot/owner will notice the diference). Wecouldnt found a "logic" response other that it needed to "disturb" theairflow to work ok.Hope this helps,SaludosGary GowerPS The Teman Monofly is a two seater of the 80's with a 503 Rotax and issimilar to the Quicksilver GT 500, in fact we nicknamed this one "ThePoorman 500" it cost him 6,000.oo Dls incluiding restoration. ________________________________________________________________________________
