Will be sending you a check very soon!-----Original Message-----
Pietenpol-List: video and gear placement
Pietenpol-List: Re: video and gear placement
I plan on attaching aileron to wing with hingehow much gap should I plan on cutting outof stock two accomadate piano hinge, I herethis is a good way to eliminate gap by using a hingeof this type?-----Original Message-----
Original Posted By: kyle ray
Subject: Pietenpol-List: video and gear placement>thanx Michael for your prompt reply to my e-mails on the above subjects. I>have posted my check for the tape and I'm certain I will find it of great>value seeing how someone else has approached the various construction>problems each Piet builder faces. In regard to the gear placement I amhappy>to get some more info on the changes that were done to Sky Gypsy. I havemy>gear positioned in accordance with the plans. I should get some clue to>whether I have a problem when I have done my pre-cover W&B but will notknow>for sure until my first high speed taxi runs on how easily the tail comes>off. One thing I have learned over the years is to carefully weigh other>builders' methods and changes but to understand that every plane is unique>unto itself and that the only thing you should rely on is your own project.>However, having said that ,I must acknowledge that I have certainlybenifited>from the many great ideas other builders have shared with me throughpersonal>correspondence.>Don Hicks>________________________________________________________________________________
thanx Michael for your prompt reply to my e-mails on the above subjects. I have posted my check for the tape and I'm certain I will find it of great value seeing how someone else has approached the various construction problems each Piet builder faces. In regard to the gear placement I am happy to get some more info on the changes that were done to Sky Gypsy. I have my gear positioned in accordance with the plans. I should get some clue to whether I have a problem when I have done my pre-cover W&B but will not know for sure until my first high speed taxi runs on how easily the tail comes off. One thing I have learned over the years is to carefully weigh other builders' methods and changes but to understand that every plane is unique unto itself and that the only thing you should rely on is your own project. However, having said that ,I must acknowledge that I have certainly benifited from the many great ideas other builders have shared with me through personal correspondence.Don Hicks________________________________________________________________________________
RUSSEL; I will send you a (free) drawing showing all the stuff needed to make thathinge/gap seal modification like Mike Cuy uses.....I kinda know thedesigner.........let me know where to send it. I ysed it on my Scout too.Earl Myers-----Original Message-----
EARL,My mailing address is box 735, Hardy, AR. 72542 THAXS A BUNCH RUSS-----Original Message-----
