In a message dated 5/6/99 3:10:51 PM Eastern Daylight Time, mboynton(at)excite.com writes:>I just got the low down on whats going on. Seems that William Wynne is still in business. He had some problem with a partner in the building he was in and is moving. I had another phone number and I talked with a worker in the other shop. He said he put a note on the door and I also had a message on his machine. It seems as thou he has been moving stuff and has not had time to return calls. I will get the low down on the new manual when I talk to him, too. I expect to talk to him soon. I am telling him to call collect. I think he has a number of people wanting to talk to him and he must have a huge phone bill.William Koucky________________________________________________________________________________
Pietenpol-List: Re: Contact with Wm. Wynne (sort of)
William,Thanks for the info.Mark BoyntonGilbert, Arizona> In a message dated 5/6/99 3:10:51 PM Eastern Daylight Time, > mboynton(at)excite.com writes:> > > If you're able to make contact with William Wynne, would you let us knowif> he's still in business. I'm one of the ones who sent a check (hasn'tbeen> cashed yet) and are still waiting for the conversion manual. Thanks.> > Mark Boynton> Gilbert, Arizona >>> > > I just got the low down on whats going on. Seems that William Wynne isstill > in business. He had some problem with a partner in the building he was in> and is moving. I had another phone number and I talked with a worker inthe > other shop. He said he put a note on the door and I also had a message on> his machine. It seems as thou he has been moving stuff and has not hadtime > to return calls. I will get the low down on the new manual when I talk to> him, too. I expect to talk to him soon. I am telling him to callcollect. > I think he has a number of people wanting to talk to him and he must havea > huge phone bill.> > William Koucky________________________________________________________________________________
Pietenpol-List:
Original Posted By: Joe Krzes
William,Let me know if you get in touch with Wynne before Tues. I may drive downthere Tues p.m. If he has moved, I not sure of where to look for him. WhenI met him last winter, he was partners in a co. that built Lancair IV's.They had 8 planes in varying stages of completion in that one hangar. Veryimpressive.________________________________________________________________________________
Pietenpol-List: Re: washout and stall
Original Posted By: "Ragan, Lawrence M."
x-mac-creator="4D4F5353"Joe,I have about 1/4 of washout and have checked and rechecked alignment,but the right wing will mush and drop before the left. No clue why. Nota problem at all, I just know that's the way it is. It's a blast to slipto the left. Full rudder. Wing down low and if the right wing starts todrop a little just a couple hundred RPM picks it right up. To get intotrouble you'd really have to force it.Craig________________________________________________________________________________
When building the 3 pc wing, is it a good idea to make sure the wings weigh the same? Our chapter had a discussion about building composite aircraft and it turns out that if you build one wing in the winter and the other in the summer (no climate control) then one wing will weigh more.Joe (reading the plans stage)>From: Craig Lawler >Reply-To: Pietenpol Discussion >To: Pietenpol Discussion >Subject: Re: washout and stall>Date: Fri, 07 May 1999 14:01:58 -0500>>Joe,>>I have about 1/4 of washout and have checked and rechecked alignment,>but the right wing will mush and drop before the left. No clue why. Not>a problem at all, I just know that's the way it is. It's a blast to slip>to the left. Full rudder. Wing down low and if the right wing starts to>drop a little just a couple hundred RPM picks it right up. To get into>trouble you'd really have to force it.>>Craig>________________________________________________________________________________
Wkoucky(at)aol.com wrote:> I just got the low down on whats going on. Seems that William Wynne is still> in business. He had some problem with a partner in the building he was in> and is moving. I had another phone number and I talked with a worker in the> other shop. He said he put a note on the door and I also had a message on> his machine. It seems as thou he has been moving stuff and has not had time> to return calls. I will get the low down on the new manual when I talk to> him, too. I expect to talk to him soon. I am telling him to call collect.> I think he has a number of people wanting to talk to him and he must have a> huge phone bill.> > William KouckyI met William Wynne a few years ago when he got to fly with SteveWittman in his Olds powered Tailwind. William was a super guy, aviationin the blood type. Just keep one thing in mind, he doesn't make aliving and probably barely recovers costs from his experiments with theCorvair engine, so be a little patient with him while he moves thingsaround. He will be the one carrying all the boxes, machine tools, etc.himself.________________________________________________________________________________
