Original Posted By:> >>> >> > RGASKIN
> >>> Subject: Re: Piet owners and builders> >>>> >>>> >>> >Speaking of metal fittings, the Christavia is full of them. I dohave a> >>> >couple of tips that are obvious to those who have done it, but maynot> >be> >>> >to others.> >>> >> >>> >1. Buy the highest powered 8" bench grinder you can find. I started> with> >a> >>> >dinky little unit that would slow right down as soon as you touchedit> >but> >>> >later bought a 1.5 hp Craftsman unit and would never go back. Even> >>> >expensive ones are pretty cheap as all it is is a motor, housing and2> >>> >wheels. Fancy ones come with a light but get a severe duty bulb, GE> >makes> >>> >one (sorry, but I gotta put in a plug for my company
. Otherwise> >you'll> >>> >constantly be replacing them.> >>> >> >>> >2. Buy an extra wheel (3/4" width, idealy) and a wheel dresser. Youcan> >>> >then round down the front edge of this wheel to cut scallops for> fitting> >>> >tube to tube. I know, I know, you aren't building a metal plane.> >However,> >>> >you still have a tube engine mount
.> >>> >> >>> >3. The easiest way to cut 4130 that I've found is with a sidegrinder.> >>> >I've tried cutting wheels in the grinder, table saw, circular saw,> metal> >>> >blades in the bandsaw a cutting torch and even a hacksaw withvarying> >>> >success. The best turned out to be a 4" B&D grinder given to me by a> >>> >neighbour for helping him move. It sat on my shelf for a year untilI> >>> >finally decided to give it a try and I only wish I had tried it> earlier.> >>> >> >>> >They are available in 4" and 6" varieties (maybe more as well) and> there> >>> >are a variety of inexpensive grinding wheels available. I generallyuse> >>> >1/16", 3/32" and 1/8" x 4" wheels. These little guys are notexpensive> >>> >(less than $100 for a perfectly good budget 4") but will cutthrought> >>> >metal as if it were butter. Even 1/4" plate will grind away. Wheelsgo> >>> >fairly quickly and it does tale a little practice to stay outsidethe> >>> >lines, but it works well.> >>> >> >>> >Both of these tools were found only after 80% of the metal work was> >>> >done. I can only imagine how much time I could have saved with the> >>> >right tools.Hope this helps.> >>> >> >>> >Ken.> >>> >> >>> >> >>> >On Wed, 16 Jun 1999, William C. Beerman wrote:> >>> >> >>> >> Randy,> >>> >> I'm one of a group of three collaborating on a long fuse Piet in> >Raleigh,> >>> NC.> >>> >> Fuselage and tailfeathers done, S T R U G G L I N G through themetal> >>> >> fittings now (making a second pass at the hinges- just a little> longer> >>> >> than plans this time).> >>> >>> >>> >> Where are you?> >>> >>> >>> >> -Bill> >>> >>> >>> >> > Date: Wed, 16 Jun 1999 13:11:51 -0400
