Pietenpol-List: plexiglass
Pietenpol-List: Re: plexiglass
I noticed most of the windshields at Brodhead were pretty thin and thisis OK. I was able to scrounge an old windshield being replaced in aMooney and as the price was right, we'll use it. It is a quarter inchthick so it's not going to be very large.Sincerely,John Langston>>>Before you invest in plexiglass check out your motorcycle buddies and >see>if they don't have cracked windshields they will give away. I used >they>and they work great. Cheap too. jas>>>>>>>>>>What thickness plexiglass did y'all use for>windscreens?>> >>JMG>>>>__________________________________________________________________________________________
What thickness plexiglass did y'all use for windscreens?JMGWhat thickness plexiglass did y'alluse forwindscreens?JMG________________________________________________________________________________
Original Posted By: Copinfo
>> What thickness plexiglass did y'all use for windscreens?> > JMGJohn- I used 1/8" LEXAN. Skip the plexi- it can crack,split, shatter internally.Lexan can be drilled, cut with a sabre saw or bandsaw, filed, bent, (cold), etc. It's more $$ but less headaches.Mike C. What thickness plexiglass didy'all use for windscreens?JMGJohn- I used 1/8 LEXAN. Skip the plexi- it can crack,split, shatter internally.Lexan can be drilled, cut with a sabre saw or bandsaw, filed, bent, (cold), etc. It's more $$ but less headaches.Mike C. ________________________________________________________________________________
Original Posted By: Michael King
Found this to be so true after 3 sets of windshields.Slow learner,Steve EldredgeSteve(at)byu.edu -________________________________________________________________________________D CuySent: Wednesday, August 11, 1999 8:45 AMSubject: Pietenpol-List: Re: plexiglassWhat thickness plexiglass did y'all use for windscreens?JMGJohn- I used 1/8" LEXAN. Skip the plexi- it can crack,split, shatter internally.Lexan can be drilled, cut with a sabre saw or bandsaw,filed, bent, (cold), etc. It's more $$ but less headaches.Mike C.________________________________________________________________________________
Before you invest in plexiglass check out your motorcycle buddies and seeif they don't have cracked windshields they will give away. I used theyand they work great. Cheap too. jas>>>>What thickness plexiglass did y'all use forwindscreens? JMG<<<<<<<<________________________________________________________________________________
