Pietenpol-List: What would I do without my Dremmel?
Once again my Dremmel comes to the rescue. Years ago before my firstproject, I asked a friend if he had a Dremmel, and if he liked it ( hewas not a builder). Said he got one for a gift, and never seemed tofind a use for it. Good I didn't listen to him. It's got to be one of the three most useful tools in the shop. Doesn'tdo large jobs, only the ones that you can't figgure out how to do , orthe space is too small. Routed in the elevator hinges flush with the router attachment. and toroute in flush gussets. A real pro job. Not a big outlay that will break the bank. Around Xmas, you can gettool, case, and flex shaft for around $75.00.A real Keeper.waltOnce again my Dremmel comes to therescue.Years ago before my first project, I asked a friend if he had a Dremmel,and ifhe liked it ( he was not a builder). Said he got one for a gift,and neverseemed to find a use for it. Good I didn't listen tohim.It's got to be one of thethree mostuseful tools in the shop. Doesn't do large jobs, only the onesthat youcan't figgure out how to do , or the space is toosmall.Routed in the elevator hingesflush withthe router attachment. and to route in flush gussets. A real projob. Not a big outlay that willbreak thebank. Around Xmas, you can get tool, case, and flex shaft foraround$75.00.A real Keeper.walt________________________________________________________________________________
Pietenpol-List: Re: What would I do without my Dremmel?
On Sun, 26 Sep 1999, walter evans wrote:> Once again my Dremmel comes to the rescue. Years ago before my first> project, I asked a friend if he had a Dremmel, and if he liked it ( he> was not a builder). Said he got one for a gift, and never seemed to> find a use for it. Good I didn't listen to him. > It's got to be one of the three most useful tools in the shop. Doesn't> do large jobs, only the ones that you can't figgure out how to do , or> the space is too small. > Routed in the elevator hinges flush with the router attachment. and to> route in flush gussets. A real pro job. > Not a big outlay that will break the bank. Around Xmas, you can get> tool, case, and flex shaft for around $75.00. A real Keeper. walt> Even cheaper than the Dremel is a good die grinder. They generally arepneumatic, so if you have a compressor you're all set. They are also a bitheavier than the Dremels and tend to compliment thenm in the shop. I haveboth and use them for different things on the plane. Ken Beanlands B.Eng (Aerospace)Calgary, Alberta, CanadaChristavia MK 1 C-GREN________________________________________________________________________________
