Pietenpol-List: HEGY PROPS
Subject: Pietenpol-List: HEGY PROPS>>Would like to know from any PIET and GN-1 builders>who are using a Cont. 65 through 80 series engine,>what size prop you suggest. And if any of you are using>HEGY props, what kind of experience have you encountered.>>I am thinking of ordering a new HEGY 72x44 wooden prop>from Mr. Hegy. I have not talked to anyone who has his>prop or has done business with the man. Any comments>or recommendations are appreciated.>>Mike>Dallas>(214) 905-9299________________________________________________________________________________
Original Posted By: fishin
Would like to know from any PIET and GN-1 builderswho are using a Cont. 65 through 80 series engine,what size prop you suggest. And if any of you are usingHEGY props, what kind of experience have you encountered.I am thinking of ordering a new HEGY 72x44 wooden propfrom Mr. Hegy. I have not talked to anyone who has hisprop or has done business with the man. Any commentsor recommendations are appreciated.MikeDallas(214) 905-9299________________________________________________________________________________
Pietenpol-List: Re: HEGY PROPS
Original Posted By: "Jack Phillips (EUS)"
My Cont A65-8 with McCauley 7148 metal prop came off a PiperPA-17---though 1 1/2 to 2 years away from flying, I expect acceptableperformance...JoeCZion, IllinoisMichael King wrote:> Would like to know from any PIET and GN-1 builders> who are using a Cont. 65 through 80 series engine,> what size prop you suggest. And if any of you are using> HEGY props, what kind of experience have you encountered.>> I am thinking of ordering a new HEGY 72x44 wooden prop> from Mr. Hegy. I have not talked to anyone who has his> prop or has done business with the man. Any comments> or recommendations are appreciated.>> Mike> Dallas> (214) 905-9299________________________________________________________________________________
Pietenpol-List: RE: HEGY PROPS
Original Posted By:> Michael King [SMTP:mikek(at)nstar.net]
The only Pietenpol I have ever flown had an A-65 with a Hegy prop. I don'tknow the particulars on the prop, but the plane had good performance. Itwould outclimb and outrun the J-3 Cub I owned at the time. 72 x 44 is apretty typical dia and pitch for a wood prop on a Continental 65.> -----Original Message-----
Mike I have owned 2 of Hegy's props.Both were of good quality for theprice.Also both ended up being cruise props as they seem to turn a littleheavier than some.Climb suffered a little but speed made up for it. My nextone from him will be a climb prop so I get all around performance.Bill-----Original Message-----
Mike the 72x44 or 72x42 are good props for the Continental 65. The 42 ismore climb and the 44 is more speed. Hegy makes great props. Sensenichprops new are a little more and are certified. If you install a certifiedengine and certified prop you only have to fly off 25 hours afterinspection. Otherwise you have to go for 40 hours.Copinfo(at)ix.Netcom.ComTim CunninghamDes Moines, Iowa (515) 237-1510>Would like to know from any PIET and GN-1 builders>who are using a Cont. 65 through 80 series engine,>what size prop you suggest. And if any of you are using>HEGY props, what kind of experience have you encountered.>>I am thinking of ordering a new HEGY 72x44 wooden prop>from Mr. Hegy. I have not talked to anyone who has his>prop or has done business with the man. Any comments>or recommendations are appreciated.>>Mike>Dallas>(214) 905-9299________________________________________________________________________________
