Subject: Pietenpol-List: hydraulic brakes> Does anyone know of a small inexpensive( ha ha ) brake caliper for a disc>brake ? Do any go carts, motor scooters, small motorcycles or smalltrailers>have disc brakes ? Any help or suggestions would be appreciated.>Don Hicks>________________________________________________________________________________
Original Posted By: Larry Ragan
Does anyone know of a small inexpensive( ha ha ) brake caliper for a disc brake ? Do any go carts, motor scooters, small motorcycles or small trailers have disc brakes ? Any help or suggestions would be appreciated.Don Hicks________________________________________________________________________________
Pietenpol-List: Re: hydraulic brakes
Original Posted By: "Jack Phillips (EUS)"
donthese four wheelers that you see running around arethe right size. I priced new ones yesterday.$104 forthe caliper and $34 for the disc. I'm heading for alarge motorcycle salvage yard to see if they have someused ones. the wheels and rims are 8 inch so might beusable too.if you see how they jump those fourwheelers, they should be strong enough. I might castmy own aluminum wheels though. still researching it.--- DonanClara(at)aol.com wrote:> Does anyone know of a small inexpensive( ha ha )> brake caliper for a disc > brake ? Do any go carts, motor scooters, small> motorcycles or small trailers > have disc brakes ? Any help or suggestions would be> appreciated.> Don Hicks> ________________________________________________________________________________
Don,It always seems that when you need something, it's not around. I had putout the word with the neighbors of what I needed. For months nothing, thenon Sunday ,last, my neighbor Nathan, comes to the door and says " I got yourbrakes". He had been down Englishtown NJ. which is a big flea market,and he had the whole front of a motorcycle removed at the steering post. Igot 2 calipers , 2 discs ( I'll have to make smaller) and one master cyl.for $8.oo.Thats the fun of building a plane, so many things going, you can just shifttill the other parts surface.walt-----Original Message-----
Thanx Del for the reply...by four wheelers are you talking about ATV's?? It sounds like that if they have 8 inch wheels.Don H.________________________________________________________________________________
yep, thats what Imean--- DonanClara(at)aol.com wrote:> Thanx Del for the reply...by four wheelers are you> talking about ATV's?? It > sounds like that if they have 8 inch wheels.> > Don H.> ________________________________________________________________________________
Thanks Walt, we do have to shift a lot so I guess I can add the brakes to the list. Actually, if something surfaces it should be a piece 'o cake to make the change. The disc can mount onto the same plate that now holds the drum, and I haven't yet started covering.Don H.________________________________________________________________________________
