It may have been inconsiderate to talk about dowsing, if someone isoffended Iapologize and will try try to remember a singleness of purpose thatbeing Pietenpols aircraft. ----- Original Message -----
Pietenpol-List: Piet Dowsing
Original Posted By: "Jack Phillips (EUS)"
Subject: Pietenpol-List: Piet Dowsing Hey gang, I'm on my way out the door to fly Piet NX899TC while theweather stays above 60 degrees. I'm taking a couple of copper wires I'mgoing to put in a coke bottle and fly over the lake to see if that waterwitching (Dowsing) thing works. Does anyone have the STC or plans for agood set I can install on the Piet? Copinfo(at)ix.Netcom.Com Tim Cunningham Des Moines, Iowa (515) 237-1510________________________________________________________________________________
Piet Dowsing
Original Posted By: mike cushway
Subject: Piet Dowsing Hey gang, I'm on my way out the door to fly Piet NX899TC while theweather stays above 60 degrees. I'm taking a couple of copper wires I'mgoing to put in a coke bottle and fly over the lake to see if that waterwitching (Dowsing) thing works. Does anyone have the STC or plans for agood set I can install on the Piet? Copinfo(at)ix.Netcom.Com Tim Cunningham Des Moines, Iowa (515) 237-1510________________________________________________________________________________
Original Posted By: Gary Meadows
Hey gang, I'm on my way out the door to fly Piet NX899TC while theweather stays above 60 degrees. I'm taking a couple of copper wires I'mgoing to put in a coke bottle and fly over the lake to see if that waterwitching (Dowsing) thing works. Does anyone have the STC or plans for agood set I can install on the Piet? Copinfo(at)ix.Netcom.ComTim CunninghamDes Moines, Iowa (515) 237-1510________________________________________________________________________________
Pietenpol-List: Re: Piet Dowsing
Original Posted By: Copinfo
My stepfather (83 yrs old) was going to demonstrate the dowsingtechnique and used a forked peach tree switch. Well it was raining whenhe started his demo and that peach switch went nuts pointing every whichway and nearly put a catch in the old man's back. He later said thatthe ground was covered with water from the rain. And that only a darnedfool would try to dowse in the rain..... Sounds reasonable to me....John W-----Original Message-----
Original Posted By: Fireman
hmmmm....don't fly over water - those landing gear legs might just start amerry little jig.> And that only a darned fool would try to dowse in the rain.....>Sounds reasonable to me.... John W -----Original Message-----NottinghamshireEnglandleo(at)deadly.demon.co.uk________________________________________________________________________________
