Del, the Corvair mount is just as easy to build as the one for theContinental. I see people worried about moving the wing back. First buildthe mount longer and the wing will not have to be moved. Second, if you dohave to adjust the wing, it is a simple task to do so. Just make sure thebraces for the front cabanes are adjustable. I did both on my Piet. Itwasn't right on the first flight, so, I adjusted it. 15 minutes work. Iflew it again, made another adjustment and it was perfect. I left thesafety wire off on the test flights. It was there for the inspection, thenremoved when the inspector left.Copinfo(at)home.comTim CunninghamDes Moines, Iowa (515) 237-1510----- Original Message -----________________________________________________________________________________Date: Fri, 05 Nov 1999 08:04:55 -0600
