Pietenpol-List: wood joysticks
Has anyone made any joysticks from wood. If so how did you construct them?. ________________________________________________________________________________
Re: Pietenpol-List: Re: pre cover insp
Original Posted By:> fishin
Hi Joe, it's Gene. Still working (kinda) on the Piet. Spent most of thelast year on the Travel Air, didnt make it to Brodhead-Pietenpol, but madeit to Brodhead Grassroots. Let me knoe what is going on. (btw, I probablywon't use the seat belts you sent, got any buyers?)----------
RE: Pietenpol-List: Big Wheels
I have them. I also noticed that I wasn't alone at Brodhead with "turfglide" tires either. they fit on any 6.00 X 6 wheel. (pick your axle size)Steve EldredgeIT ServicesBrigham Young University> -----Original Message-----
Re: Pietenpol-List: wood joysticks
Original Posted By: "Conoly"
Subject: Re: Pietenpol-List: wood joysticksWhy would you consider using wood for a joystick? I believe most of ushave seen a baseball bat crack, and I for one wouldn't want to be overthe threshold and hit a gust of wind and make a quick correction only tofind the cracked wood joystick stub in my hand.If you feel that you have to have wood, then why not use the wood as asleeve over the metal. This of course is adding additional weight and Ithought the idea was to keep things as light as possible, but to each"his own".________________________________________________________________________________
> > > > :> > >> >> > Greg Yotz wrote:> >> >> (trying to rig and get ready for fabric)> >>> >> I hear talks of rigging and fabric selection and coverings but> >> can't recall any talk of pre-covering inspections. is this being> >> done and by who or is the only inspection the one prior to test> >> flights...the reason for my question is that my chapter does not> >> have a tech advisor and I'm not that far away from thinking> >> coverings.> >> > regards> > JoeC> > Zion, Illinois> > ps--if you haven't guessed, this is my first project> > > > ________________________________________________________________________________
