Pietenpol-List: Pietenpol Fabric
Would like to hear from someone as to the number of yards of fabric Ishould order, to completely cover a long fuselage Piet.________________________________________________________________________________Date: Fri, 17 Dec 1999 20:10:02 -0500
Re: Pietenpol-List: Pietenpol Fabric
Original Posted By:> Jerome Bush
I bought 40 and did not use it all.Doug Hunt CGCGJ----------
Original Posted By:> Doug
The wings would have to be almost 20 yards themselves (or itself, if you'rea purist) Another ten for the fuselage (always a lot of waste). A few forthe tail surfaces. It can't be far below 40 yards, can it?----------
Original Posted By:> Gene Rambo
40 will be lotsDoug----------
Original Posted By: "Domenico Bellissimo"
Subject: Re: Pietenpol-List: Pietenpol Fabric>>I am looking for the best place to buy 1.8 oz ceconite. And what to paint>it with. I have heard of using house paint. Is this a good practice?>>Steve>> writes:>> >>>> I think I purchased 50 Yards x 65", and had a few yards left over.>> Dom.>>>>>>>>>>>>Steve W GN-1 builder>IHA #6>>________________________________________________________________________________
I think I purchased 50 Yards x 65", and had a few yards left over.Dom.________________________________________________________________________________
Subject: Re: Pietenpol-List: Pietenpol FabricI am looking for the best place to buy 1.8 oz ceconite. And what to paintit with. I have heard of using house paint. Is this a good practice?Steve writes:> > > I think I purchased 50 Yards x 65", and had a few yards left over.> Dom.> > > > > Steve W GN-1 builderIHA #6________________________________________________________________________________
NO. Use Poly-fibre ( the old Stits) get it at AS&S or other places. Youwont be sorry. I've seen people use house paint, but it just can't take thesun, or most important, the fabric flexing. Did my first project for lessthan $400.00, and it handles great.walt evans-----Original Message-----
Original Posted By: Mark Morgan
Subject: Re: Pietenpol-List: Pietenpol FabricIn a message dated 12/19/99 8:11:27 PM Central Standard Time, vistin(at)juno.com writes:>I'm using Priemium Rust-Oleum, Oil Based Enamel, 7715 Aluminum paint. Ya gotta put it on just enough to penetrate the fabric, and form a mechanical bond. Paint dosen't stick to Dacron. Then the second coat to eliminate Ultra Vilot (UV) rays. I'll end up with a silver wing...light weight, easy to apply, (probably a roller) and inexpensive. I'll trim the wing with red paint to match the fuselage.Chuck G.Wichita KS________________________________________________________________________________Date: Sun, 19 Dec 1999 22:29:47 -0500
Original Posted By: "Tim Cunningham"
Subject: Re: Pietenpol-List: Pietenpol Fabric>Mornin Walt! Thanks for your input on this. Now could you send me a list>of the products you used and the weight of the fabric. I am just trying>to do the same as everyone else and save weight.>Again thanks for this info.>Steve>________________________________________________________________________________
Fw: Pietenpol-List: Pietenpol Fabric
Steve,My first project was a Fisher 404, which I'm flying now. I too took mythinking toward house paint or car paint, but if you look at the facts,there just is no comparison.First the price ...the first two steps are poly brush ( about $50.00 a gal),and Poly spray ( silver) about $50.00 a gal) and lastly the color coat,which is Poly Tone. ( about $50.00 to $70.00 for all colors except thereds) and about $100.00 for the red based colors.havn't covered the Piet yet , so I can just talk about the Fisher. Greenbody with "white" wings...for the whole plane was..2 gal poly brush @ $50.40$100.80 (new prices)1 gal poly spray @ $49.60$49.60 "1 gal poly tone "white" for wings and tail surfaces @ $38.00 = $38.002 qts. poly tone green for body @ $19.20 $19.20 2 gal reducer $ 28.30$56.60 total $264.20this doesn't include MEK, tapes , rib stitching,brushes etc. I built and fly my Fisher as a U/L so I used 1.8oz fabric and a minimum ofcoats ( 3 poly brush,3 poly spray, and 3 poly tone) these coats can be doneat about 20 min. intervals, and It's a dream to work with.Just remember, because Poly fiber isn't actually a paint, each coat that youput on, actually "melts" and becomes part of the last layer.And...it's flexible and wont crack due to fabric flexingAnd...no mater how old the poly fiber is you can clean it and apply moreright over it.And...if you use house paint ( and how often do you have to repaint ahouse?) You'll have to recover the plane. You'll never be sorry if you use Poly Fiberwalt evans-----Original Message-----
> > > Would like to hear from someone as to the number of yards of fabric I> should order, to completely cover a long fuselage Piet.> > > > > ________________________________________________________________________________
Original Posted By:> > Jerome Bush
> > > I bought 40 and did not use it all.> Doug Hunt CGCGJ> > ----------
Original Posted By: "oil can"
> > > > > > Would like to hear from someone as to the number of yards of fabric I> > should order, to completely cover a long fuselage Piet.> > > > > > > > > > > > > > ________________________________________________________________________________
Original Posted By:> > Doug
> > > The wings would have to be almost 20 yards themselves (or itself, ifyou're> a purist) Another ten for the fuselage (always a lot of waste). A fewfor> the tail surfaces. It can't be far below 40 yards, can it?> > > ----------
Original Posted By:> > > Jerome Bush
> > > > > > I bought 40 and did not use it all.> > Doug Hunt CGCGJ> > > > ----------
Original Posted By: StOrMiN3(at)aol.com
> > > > > > > > > Would like to hear from someone as to the number of yards of fabricI> > > should order, to completely cover a long fuselage Piet.> > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
