Pietenpol-List: Re: Dave's W&B
just a little skin gonemy wife the RN loves when i come home with band-aidsthe rudder bar support bracket is the one that got away.. but its bolted in nowjeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/bar_ ... ___Subject: Pietenpol-List: Re: Dave's W&B
Just as a note to O 235 prospects,I found no way with the long fuselage to nothave the Heliocamper look.I like it but some traditionalist think its abhorrent,notmy problem.I would suggest not making your motor mount until your done covered,figureout total FWF weight including prop and cowling and then figuremount length based on where you want your CG to be.Or you can do it all a coupleof times for practice.dave--------taking to hangarRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Dave's W&B
Re: Pietenpol-List: Re: Dave's W&B
You want flop? I geeve you flop!I'm pretty agile, now. Later, down the avenue ofyears? Probably not. I don't want to have to giveup Piet flyin' because I can no longer get in thesilly thing!Clif :-)> Dave,> I just realized - you don't have a center section flop or a cut-out. No > wonder it's hard to get in and out!> Cheers,> Dan________________________________________________________________________________
RE: Pietenpol-List: Re: bellcrank geometry
Jeff, again, I'm not past this point but my understanding is it helpsforward of the bellcrank also.JackDSM-----Original Message-----
> And N8031 has a cut-out which works> pretty well, too.> > Dan> > > On 05/11/2011 10:45 PM, Clif Dawson wrote:> > You want flop? I geeve you flop!> >> > I'm pretty agile, now. Later, down the avenue of> > years? Probably not. I don't want to have to give> > up Piet flyin' because I can no longer get in the> > silly thing!> >> > Clif :-)> >> >> Dave,> >> I just realized - you don't have a center section> flop or a cut-out.> >> No wonder it's hard to get in and out!> >> Cheers,> >> Dan> > -- > Dan Yocum> Fermilab 630.840.6509> yocum@fnal.gov, http://fermigrid.fnal.gov> "I fly because it releases my mind from the tyranny of> petty things."> ________________________________________________________________________________Date: Thu, 12 May 2011 11:37:09 -0500
