Pietenpol-List: Metal C/S gasoline tank
I sent this originally to Gary Booth's address, but they kicked it back saying that the address failed -- for some reason. So I'm sending it again on the Piet list. Gary, I'm just about to the point of building up my center section. I was originally planning on making a C/S tank of composites but with the advent of Ethenol in our gasoline I figured I had better build one of metal. I remembered a picture you posted last December of your gas tank. I have some questions:1. What is its capacity and it's dimensions?2. I assume it is made of aluminum -- is that correct? If so, what grade and thickness of aluminum did you use?3. What kind of sealer did you use?4. Are they hardware store rivets or did you get them from an A/C materials supply?5. Is the top of the tank covered?6. What are the two large rectangular holes in the top of the tank?7. Do you have any more pictures of the tank -- maybe in process of building?8. Do you have any plans? If so, how could I get a set?I would really appreciate any information you can give me. Your tank looks about what I need. I can't weld so a tank made of steel is out. Thanks, Chuck________________________________________________________________________________
RE: Pietenpol-List: Metal C/S gasoline tank
Chuck,You may have missed the 'e' on the end: gboothe5(at)comcast.net. I just came indoors to grab a bite.then back out to my wing! Later tonightI'll send you a bunch of pics, but for now, check out my embedded answersbelow. I am grateful for inspiration from Jim Markle and all the pics onwww.westcoastpiet.com under his name, and to Jack Phillips for providing meexcellent technical advice.Gary
Re: Pietenpol-List: Metal C/S gasoline tank
Original Posted By: Gboothe5
Yeah, Gary, I missed the 'e' at the end of Booth. Thanks for the reply. Chuck ----- Original Message -----
Pietenpol-List: Re: Inspection done,fly thursday weather permitting
should be fun,dave--------taking to hangarRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/2011 ... ___Subject: Pietenpol-List: Re: Inspection done,fly thursday weather permitting
Original Posted By: "Jack"
That is fantastic. I am proud for you Dave. Let me know how it goes.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers done, fuselage rollingusing Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Inspection done,fly thursday weather permitting
Dave,What a milestone CONGRATULATIONS...Be Safe,Jack-----Original Message-----
