Here=99s picture of my throttle =9Cquadrant=9D cover before....Here it is, after sending 3,000 miles to engraver for modification...(I=99ve added a primer set-up)...Why send it 3,000 miles for engraving, you ask? Fellow Piet builder, Jerry Dotson, does engraving as sort of a hobby, and offered! I think it=99s cool to have contributions from other builders!THANKS, JERRY!!!Gary ________________________________________________________________________________
Pietenpol-List: Throttle cover
RE: Pietenpol-List: Throttle cover
Very nice, Gary! I can hardly wait to see your Pietenpol floating in overthe corn at Brodhead.Jack PhillipsNX899JP "Icarus Plummet"Smith Mountain Lake, Virginia _____
Pietenpol-List: Re: Throttle cover
That is a beautiful shot! Congratulations on your luck in getting it.LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Throttle cover
Original Posted By: Matthew VanDervort
Nice...... Aircraft Spruce is gonna want to carry them...!--------Jake Schultz - curator,Newport Way Air Museum (OK, it's just my home)Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Throttle cover
Jack your report and Jeff Boatright's opinion of his Cloudcars prop does my heartgood. I have one still in the box and looking forward to the day I can sayhow great the prop is! Note the 3/4" pipe engine mount. I still have not builtthe mount. The prop is 76X44.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers done, fuselage rollingusing Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/a28_ ... ___Subject: Re: Pietenpol-List: Throttle cover
Gary,Beautiful work and attention to detail!! These are the little things that you will be very glad you took the time for. Very unique and elegant.Dan HelsperPoplar Grove, IL.________________________________________________________________________________Date: Mon, 20 Jun 2011 06:48:26 -0500 (GMT-05:00)
