How Neat!Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Prop-carving CD, The All-Power Tool Method
Original Posted By: "jim"
Hello Good People,I was just informed, by one of the more distinguished members of our group, that ACS is out-of-stock of this highly-popular informative essay. Can't imagine why, but FYI this book can now be down-loaded as an e-book from Aircraft Technical Book Co. http://www.actechbooks.com/products/act615/Good project for the upcoming winter months. :O)Dan HelsperPuryear, TN________________________________________________________________________________
Pietenpol-List: Re: Prop-carving CD, The All-Power Tool Method
Original Posted By: Dan Yocum
i recommend it..this is the result of buying this easy to follow set of instructionsjeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/prop ... __________
Re: Pietenpol-List: Re: Prop-carving CD, The All-Power Tool Method
Buy the CD, make a prop, get a wife?!?? Thanks, I'll pass. I've already got oneof those! That's beautiful. And the prop's not bad, either! Great job!-- Dan Yocumyocum137(at)gmail.com"I fly because it releases my mind from the tyranny of petty things."On Sep 4, 2011, at 9:05 AM, "bender" wrote:> > i recommend it..> this is the result of buying this easy to follow set of instructions> > jeff> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 374#351374> > > > > Attachments: > > http://forums.matronics.com//files/propwife_402.jpg> > > > > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Re: Prop-carving CD, The All-Power Tool Method
Jeff;With only four bolt holes in the prop hub, I take it you'reputting that prop on a Ford 'A'?Oscar ZunigaAir Camper NX41CC "Scout"Flying Squirrel N2069Z "Rocket"Medford, ORwebsite at http://www.flysquirrel.net ________________________________________________________________________________Date: Mon, 5 Sep 2011 22:16:23 -0700 (PDT)
Original Posted By: "bender"
You got it Oscar...its a 76x42...here it is installedjeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/wood ... ___Subject: Pietenpol-List: Re: Prop-carving CD, The All-Power Tool Method
Original Posted By: Dan Gaston
Wouldn't have done it without your help Dan..i've read lots of stuff about carving and didn't quite get it till i got The All-PowerTool Method... and i'm not being paid to say iti have friend that want me to carve wall hangers now... depending on how this one works on the piet i may make spares or other shapesand pitchesRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 06 Sep 2011 13:31:09 -0400
Original Posted By: bender
Jeff,Thank you for the kind words. I myself was amazed at being able to do something that I always considered as a "black art", but after having observed Jerry Thornhill at OSH , and having done it myself, I thought that this simple set of instructions should be written down and passed on to others. To my knowledge this type of instruction does not exist in this basic form anywhere else. I can't wait to see how your 42" pitch prop performs. It would be great if you did a thrust test with the "Piet List-Industrial Fish Scale". Then we all would have some hard data to compare.Dan HelsperPuryear, TN-----Original Message-----
Pietenpol-List: Push pull set-up
Ken;What I have done many times when I needed to figure outgeometries is to get some cardboard, push pins, twine, sticks,and similar materials and just mock up the assembly in 2-D to see ifit works. You make the cutouts full-size and then just tackthem flat to your work table and see how they work.I'll bet that in 15-20 minutes youcould make up your bellcrank, control stick, and pushrodassembly out of stuff you have laying around and then seewhat kind of elevator travel you get with the availablefore-and-aft stick travel. Just put a couple of push pinsin the table as "control stops" to limit the stick travel,then see what kind of up and down arc you get from the "elevators"... which can be made out of anything.Oscar ZunigaAir Camper NX41CC "Scout"Flying Squirrel N2069Z "Rocket"Medford, ORwebsite at http://www.flysquirrel.net ________________________________________________________________________________
RE: Pietenpol-List: Re: Prop-carving CD, The All-Power Tool Method
Jeff,I am in procession of Dan's fish scales, waiting for time to re-pitch myprop.or for someone in immediate need to ask for them. If you want to dothrust test, and use Dan's scales, just email me off-list.Gary
