Original Posted By: "Jack"
Hey, I have my fuse mostly done and I was wondering if there's anyone that hasa plane I could look at. I've got a stack of visual questions. Thanks.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Piet builders in northern ill southern wi.
Re: Pietenpol-List: Piet builders in northern ill southern wi.
Original Posted By: "bradandlinda tds.net"
Hi Steve,I=99m basically NE of Tokyo on the Kanto plains.....one of the few flat areas in Japan!Great to hear you visited Japan. As you would have noticed, it is a very diffrent world to what we are used to!Both Piets havn=99t had much done on them for quite a while but here are some photos. (shrunk in size to save bandwidth).The fuz on wheels (with two aeroplane noise makers in the cockpits) is #1 Piet. It belongs to a Japanese bloke that I work with. #2 photo=99s are of my project (way behind #1 Piet). The rib shots show one panels worth but all of the ribs are now complete.The fin/rudder are hinged with Vi Kapler=99s hinges.Hope to get on with things again soon!Mark>I'm just curious, where in Japan are you located? >Do you have any pictures of your Piet projects?>Steve Ruse>Norman, OK ________________________________________________________________________________Date: Tue, 13 Dec 2011 10:08:22 -0600Subject: Re: Pietenpol-List: Piet builders in northern ill southern wi.
Re: Pietenpol-List: Piet progress
Subject: Re: Pietenpol-List: Piet progress
Subject: Re: Pietenpol-List: Piet progressThe compression sprins are stiffer than the coil springs. You want the spring tensionto match the effectiveness of the aerodynamic rudder. I once flew a clippedwing Cub that the owner had put on stiffer t/w springs. On t/o with the t/won the ground the rudder input was super sensitive, and when the tail cameup I had to add more rudder to keep it going straight. Even worse, on landingwith correct rudder input, when the t/w touched down it immediatelyveered sharplyoff. It became real squirly on roll out. With the spring tension matched tothe aerodynamic rudder as the tail comes up on t/o no change in rudder inputshould be needed. Brad WilliamsOn Mon, Dec 12, 2011 at 5:27 PM, John Kuhfahl > wrote:I'm the one restoring/improving a 1970's Piet. I am a self-admitted lurker--Youguys and this list are the best...In the archives you taught me how to hook upmy tail wheel. (it was not made steerable originally). I am definitely goingwith compression springs in my cable control. They run nicely through the largebelly inspection plate I installed. Will try to get this guy back together by this spring to formation fly with OscarZungia before he brings his baby back to Oregon.-- John Kuhfahl, Lt Col USAF (Ret), President, KUHLCOUPER LLC _blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com _blank">http://www.matronics.com/contribution " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________Date: Tue, 13 Dec 2011 15:54:25 -0800 (PST)
Original Posted By: John Kuhfahl
Original Posted By: "Scott Knowlton "
Compression or tension spring is not the question the question is spring rate or pounds per inch.You want the rudder to move easier than the tail wheel. You want the first few degrees of rudder to actually be somewhat free and not hard coupled or you will be dancing.Sent from my iPhoneOn Dec 13, 2011, at 1:27 PM, John Kuhfahl wrote:> Brad and all,> Hmm--well I thought I had it figured out. Good point--I hear you.I am hoping I can adjust out differences between the wheel and the rudder. I put in some slack on the wheel so the rudder moves before the wheel does. Ill do some serious taxiing to see how it works. I can always go back to tension spring. How "bout both? John> > On Tue, Dec 13, 2011 at 10:59 AM, bradandlinda tds.net wrote:> The compression sprins are stiffer than the coil springs. You want the spring tension to match the effectiveness of the aerodynamic rudder. I once flew a clipped wing Cub that the owner had put on stiffer t/w springs. On t/o with the t/w on the ground the rudder input was super sensitive, and when the tail came up I had to add more rudder to keep it going straight. Even worse, on landing with correct rudder input, when the t/w touched down it immediately veered sharply off. It became real squirly on roll out. With the spring tension matched to the aerodynamic rudder as the tail comes up on t/o no change in rudder input should be needed. Brad Williams> > On Mon, Dec 12, 2011 at 5:27 PM, John Kuhfahl wrote:> > I'm the one restoring/improving a 1970's Piet. I am a self-admitted lurker--You guys and this list are the best...In the archives you taught me how to hook up my tail wheel. (it was not made steerable originally). I am definitely going with compression springs in my cable control. They run nicely through the large belly inspection plate I installed.> Will try to get this guy back together by this spring to formation fly with Oscar Zungia before he brings his baby back to Oregon.> -- > John Kuhfahl, Lt Col USAF (Ret), > President, KUHLCOUPER LLC> > > _blank">www.aeroelectric.com> .com" target="_blank">www.buildersbooks.com> ="_blank">www.homebuilthelp.com> _blank">http://www.matronics.com/contribution> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List> tp://forums.matronics.com> _blank">http://www.matronics.com/contribution> > > > > _blank">www.aeroelectric.com> .com" target="_blank">www.buildersbooks.com> ="_blank">www.homebuilthelp.com> _blank">http://www.matronics.com/contribution> " target="_blank">http://www.matronics.com/Navigator?Pietenpol-List> tp://forums.matronics.com> _blank">http://www.matronics.com/contribution> > > > > -- > John Kuhfahl, Lt Col USAF (Ret), > President, KUHLCOUPER LLC> > ===============================================================================================================================================================================> ________________________________________________________________________________
Subject: Re: Pietenpol-List: Piet progressDue to the effect of gyroscopic precession of the prop you will always requirea further input of rudder pressure in a tailwheel aircraft when transitioningfrom three point to two point in the take off roll. This is regardless of tailwheelrigging. Scott Knowlton. -----Original Message-----
Re: Pietenpol-List: A few pics of today's cold flight
A friend of mine once built a small Jungster in his carport. I never saw it after it was finished. It, too, was VERY small. ----- Original Message -----
Pietenpol-List: Re: Piet builders in northern ill southern wi.
Original Posted By: "bill55"
Westcoastpiet also about a gazillion pictures of every conceivable piece and parton the pietenpol. JimRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Piet builders in northern ill southern wi.
