New guy here.I'm currently building my Model A motor for my Piet.What RPM do you Model A guys run?What prop?Anyone here running the dual plug Lion Speed Heed IV?Running two mags for a dual ignition system should be pretty reliable one wouldthink.Thanks CLRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Model A Prop
Re: Pietenpol-List: Model A Prop
This is the aluminum strut from Carlsons that I used. Plenty big for the Piet. Don't forget you have four of these going for you at all times.Dan HelsperPuryear, TN________________________________________________________________________________Subject: Re: Pietenpol-List: Model A Prop
Original Posted By: Piet2015
New guy,I get 1860 RPM static on a 76/46 prop on my Ford A. Ran a side-mounted mag for awhile until it chewed-up my timing gear. Had to tear-down my entire engine. Now I am running with one crank-driven Slick. I would like to find a WICO head-driven mag to run spark to my dual-plug head that I still have.Dan HelsperPuryear, TN-----Original Message-----
Pietenpol-List: Re: Model A Prop
Hi DanThanks for the prop info.If I could find a Condor timing cover I was thinking the additional accessory bossand standard boss could be use to attach a dual mag mount driven off the crankvia a dual pulley. The aluminum cover would also help offset the weight ofthe second mag.Are you a member of Secrets of Speed Society (SOSS)? Members get free ads in themagazine. I'm sure someone there has what you are looking for.CLRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By: macz(at)peak.org
