Hey Mikey (and rest of Piet gang)Yes I am still alive, just haven't been on the forum for a while. As many of youguys have said you don't make much sawdust sitting in front of a computer. Anyhow after seven years I had everything done but the paperwork, renting a hangerand finding a trailer to drag everything to Meadow Lake airport (East of ColoradoSprings). But as you know I have one of those crank snappin Vairs andI kept thinking about Randy telling me about his crank snapping episode and decidedto pull the engine off and install a Weseman 5th bearing and higher capacityoil pump, (I can almost hear Jack snickering in the background). Am almostdone with that so I can soon do a final W&B and start looking for that hanger(and take a couple lessons in a tail dragger of some sort).rick--------Rick HollandRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Re: calling for a Rick Holland update---come in Rick....do
RE: Pietenpol-List: Re: calling for a Rick Holland update---come in Rick....do
Way to go, Rick! Will we be seeing this one at Brodhead this summer?Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Pietenpol-List: Re: put your cards on the table Gents and Ladies!
Started building NX510JD July, 2009Sitka spruce and certified plywoodLong fuselageWingspan 32.5 feet one pieceAll control surfaces hinged gap-less with piano hinge16.5 gallon airfoil shaped wing tankCovered with 2.7 oz Dacron using Stewart systems adhesivePainted with Rustoleum oil base Regal Red fuselage, v fin and rudder. The wing,horizontalstabilizer, and elevators are painted with Rustoleum oil base SafetyYellow.now in final assemblyJenny style gear with Kawasaki dirt bike forged aluminum 21" wheels, mechanicaldisc brakesLycoming O-235 C2C 115 HP @ 2800 rpmJay Anderson CloudCars prop 76 X 44--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009thru covering and painting, now in final assembly21" wheelsLycoming O-235 C2CJay Anderson CloudCars prop 76 X 44Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By: "at7000ft"
Thanks Bill, those are the kind of pictures I was looking for.--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: calling for a Rick Holland update---come in Rick....doyou r
