Pietenpol-List: Re: static port plugging on ASI and ALT and Jerry's 1st
Does anyone know of this fellow or plane? Sounds like the pilot is OK which isgood news.http://www.ntsb.gov/aviationquery/brief.aspx?ev_id 120510X35303&key=1--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: static port plugging on ASI and ALT and Jerry's 1sttaxi tex
Original Posted By: "Bob edson"
Thanks for the kind words and encouragement. I do have a plug with a tiny holein it in the static port. I will climb that mountain and let you all know whatfixes it.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009thru covering and painting, now in final assembly21" wheelsLycoming O-235 C2CJay Anderson CloudCars prop 76 X 44Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
