Pietenpol-List: AN Bolt deciphering - Resource
Thanks Guys!Believe it or not, the hardest part isn't the building, it is the compilation ofthe steel parts needed to order from ACS!I have spent the last few hours looking at all I need to order to build the fusecontrol stuff. Part of the fun!Vic, I will call you tonight as I see you called when I was away.MarkRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 13 Jun 2012 22:46:25 -0700Subject: Pietenpol-List: AN Bolt deciphering - Resource
Re: Pietenpol-List: AN Bolt deciphering - Resource
Subject: Re: Pietenpol-List: AN Bolt deciphering - Resource
Mark, the main difference is price. In the ACS listing an AN3-7A (undrilled) is $0.12 -- an AN3-7 (drilled) is $0.52. That 40-cent difference would build up when you start ordering your hardware. Chuck ----- Original Message -----
RE: Pietenpol-List: AN Bolt deciphering - Resource
Mark,Aside from the cost difference, my earlier version of AC43.13 states,".Bolts 5/16" diameter and over with cotter pinholes may be used withself-locking nuts." Inference from that, along with my recollection from A&Pschool, is that smaller bolts with cotter pinholes would not be used withfiber locknuts.Gary from Cool _____
