Pietenpol-List: Re: prop clearence
It is with heavy hearts that my wife and I pass on our wishes and prayers to Kevinand Shelley and are gracious for the opportunity to have met briefly on Saturday.--------Adrian MWinnipeg, MBCanadaRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: prop clearence
When I flew Dick/Ted's Lablond I was told to keep the tail down,on take-off andlandings, as clearance was Minus 3"Lambert required 8" with a 76" propWerner with a 82 " prop had 4"Funk stock=10",76"Funk inverted 10",76"Ford A 9" 76"Different engines had different crank to ground distances.Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: motorcycle wheels - bronze bearings
Original Posted By: Rick
those that have used motorcycle wheels with Bronze bearings=2C - where did you get your material for the bearings. I'm assuming you used sleeved (flanged) bearing but I can only find stuff that's 1 1/2" long. Was thinking it should be the entire hub length.Tom B. ________________________________________________________________________________Subject: Re: Pietenpol-List: motorcycle wheels - bronze bearings
Tom,Get them from Mcmaster CarrRick SchreiberNX478RSValparaiso, InSent from my iPadOn Jul 23, 2012, at 8:36 PM, TOM MICHELLE BRANT wrote:> those that have used motorcycle wheels with Bronze bearings, - where did you get your material for the bearings. I'm assuming you used sleeved (flanged) bearing but I can only find stuff that's 1 1/2" long. Was thinking it should be the entire hub length.> > Tom B.> > ============================================================================================================================================> ________________________________________________________________________________
Re: Pietenpol-List: Kevin
Original Posted By: "woodflier(at)aol.com"
Subject: Re: Pietenpol-List: KevinKevin and Shelly, Along with all the other offers please holler if I can do anything.(Tricare, TXARNG, or help unload.) I will be moving to San Antonio sometimein August (hopefully the 12th or so) and will contact you then. You are both in my prayers. Call or email if you need anything.-Blue Skies,Steve D580-484-1024________________________________________________________________________________
Subject: Pietenpol-List: KevinJust adding our thoughts and prayers. Matt and Lynne PaxtonConnected by DROID on Verizon Wireless________________________________________________________________________________Date: Tue, 24 Jul 2012 05:29:03 -0700 (PDT)
Original Posted By: "bender"
Thoughts and prayers for Kevin, Shelly and their family...Also for Kevin's fullrecovery.....Really sorry to hear this news..... Larry & Sheri VetterRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: prop clearence
Model A and 76" prop.....9 inches ..jeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 24 Jul 2012 08:30:27 -0500
Pietenpol-List: Re: Kevin
Original Posted By: Jim Boyer
