Original Posted By: JOSEPH SWITHIN
Pietenpol-List: corvair cowl
Pietenpol-List: Re: Almost Finished With Wing Ribs
Hi TerryI made a "dunk tank" out of a 1 ft x 6 ft spare piece of MDF and some 2 inch siderails and did the full immersion baptism of the ribs. Used thinned spar varnishand did it twice, looking for penetration and not beauty.The benefit of doing it before storage is that they are sealed and more or lessimmune to any affects that the environment might have. Of course I'VE neverspilled anything accidentally or had mice nest someplace they shouldn't...Ref the attachment to spar discussion -- I tend to take the nails/Jack Phillipsside rather than glue for one reason. If you ever have to rebuild a wing (likeAxel, Jack, Douwe, and Gardiner), it's easier to disassemble nails than glue.Now if you used a relatively weak glue that would hold things in place untilafter rib stitching but could be broken without damage to the ribs or spar,that would work too.DaveRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Almost Finished With Wing Ribs
RE: Pietenpol-List: corvair cowl
Hans, JoeI think I have a copy of the drawing. See Attached.ChrisSacramento, CaWestcoastpiet.com _____
Re: Pietenpol-List: Re: Corvair cowl
Original Posted By: Rick
If i not remember bad, this cowl pattern is for a Continental A65.regards--------Mario GiacummoPhotos here: http://goo.gl/wh7M4Little Blog : http://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: Corvair cowl
Original Posted By: Mario Giacummo
Mario,It is for a Corvair.Rick SchreiberSent from my iPadOn Mar 13, 2013, at 6:37 AM, "giacummo" wrote:> > If i not remember bad, this cowl pattern is for a Continental A65.> > regards> > --------> Mario Giacummo> Photos here: http://goo.gl/wh7M4> Little Blog : http://vgmk1.blogspot.com> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 144#396144> > > > > > > > > > ________________________________________________________________________________
Original Posted By: Hans van der Voort
Subject: Re: Pietenpol-List: Re: Corvair cowlokMario Giacummo. -..- .. ... - .. .-. / . ... / ..- -. / .... . -.-. .... --- --..-- /...- .. ...- .. .-. / . ... / ..- -. / .- .-. - .2013/3/13 Rick >> Mario,> It is for a Corvair.> Rick Schreiber>> Sent from my iPad>> On Mar 13, 2013, at 6:37 AM, "giacummo" wrote:>> mario.giacummo(at)gmail.com>> >> > If i not remember bad, this cowl pattern is for a Continental A65.> >> > regards> >> > --------> > Mario Giacummo> > Photos here: http://goo.gl/wh7M4> > Little Blog : http://vgmk1.blogspot.com> >> >> >> >> > Read this topic online here:> >> > http://forums.matronics.com/viewtopic.p ... 144#396144> >> >> >> >> >> >> >> >> >> >>>________________________________________________________________________________Date: Wed, 13 Mar 2013 06:35:36 -0700 (PDT)
