Original Posted By: "bender"
Beer drinking buddies are the most helpful!!GaryNX308MBSent from my iPhoneOn Jul 3, 2013, at 2:06 PM, "Dortch, Steven D MAJ MIL USA NGB" wrote:> > UNCLASSIFIED> I was strongly advised by a buddy with two fingers missing on his right hand."make sure you put your beer on the same side of the band saw as your dominanthand!" > > On 07/03/13, jarheadpilot82 wrote:>> >> Note to self->> When cutting small wood pieces on the bandsaw, take phone out of pocket andturn it on silent.>> >> A few weeks ago I was momentarily distracted at said bandsaw and cut a chunkout of the end of my left middle finger. About a half-dime size chunk.>> The real problem came when I couldn't get it to stop bleeding after 24 hours.(Curse you, Coumadin!)>> Ended up In the ER and they got it stopped- $800.00 LATER! I did, however endup with an extra 2 weeks off work. It's hard to turn the tiller with your leftdirty finger wrapped.>> >> -------->> Semper Fi,>> >> Terry Hand>> Athens, GA>> >> >> >> >> Read this topic online here:>> >> http://forums.matronics.com/viewtopic.p ... 853#403853> UNCLASSIFIED> > > > ________________________________________________________________________________Subject: Pietenpol-List: repair
Pietenpol-List: Re: repair
Well. .. got the spar splice done. .Put fabric on top yesterday. . Covered the bottom today. Not that bad of a repair. . Ordered tubing to just build anotherAxel. .. probably easier than fixing the original. Engine is next. .. flying again soonJeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/2013 ... ___Subject: Pietenpol-List: Re: repair
Jeff; don't feel like the Lone Ranger. I'm glad nobody can see Scout right now.The wings are still off the airplane and all the inspection covers are off.I still need to make glue repairs to a rib glue joint and a splintered spoton the plywood leading edge of one of the wings before they will be done. Thetailwheel is coming off so I can take a slight twist out of the leaf springsthat has the tailwheel wearing unevenly. I need to patch a hole that I cut inone of the ailerons to remove a loose piece of hardware that was rattling aroundin there (a random nutplate). The engine cowlings are off and the plug wiresare dangling willy-nilly, since I'm replacing the cooling eyebrows with thenew set that I have. The front seat bulkhead is torn out; I'm rebuilding itwith a new one, along with Mike Cuy-style rudder stops and an extra brace acrossthe front of it to keep it from ever ungluing again when I "exercise" therudder bar to its full extents in a crazy crosswind. The turn and bank is outof the panel for overhaul. The braided flex fuel line from the shutoff valveto the gascolator is out of the airplane, to be replaced with aluminum tubing.The aileron control cables are dangling in the cockpit. The ELT battery isout of date and needs to be replaced. The gear legs need touch-up paint, asdo two fabric repair patches at the lift strut attach points (still in pink).Gaaa-!!! Will this thing ever fly again? Will the engine even start? PoorScout!!!--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: repair
Oh, yeah, and I forgot... the centersection flop is coming off so I can replacethe mangled aluminum piano hinge with a steel one. The list of squawks seemsto be getting longer instead of shorter, and here we are almost halfway throughsummer!!--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: repair
Geez Oscar... I thought for a moment you were describing my last physical. I thinkI sound more like Scout recently!Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Re: repair
Original Posted By: airlion2(at)gmail.com
Impressive work Jeff!You are one quick builder my friend! Let us all know what you find with theengine.Fall flying is the best.Douwe________________________________________________________________________________Subject: Re: Pietenpol-List: Re: repair
Original Posted By: Jim Boyer
Hey Oscar, you are dragging your tail. Get moving and get to work. It will flyagain. Gardiner. By the way. What happened to your scout? Was it an accidentor just an annual.Sent from my iPadOn Jul 4, work.2013, at 12:44 AM, "taildrags" wrote:> > Jeff; don't feel like the Lone Ranger. I'm glad nobody can see Scout right now.The wings are still off the airplane and all the inspection covers are off.I still need to make glue repairs to a rib glue joint and a splintered spoton the plywood leading edge of one of the wings before they will be done. Thetailwheel is coming off so I can take a slight twist out of the leaf springsthat has the tailwheel wearing unevenly. I need to patch a hole that I cutin one of the ailerons to remove a loose piece of hardware that was rattling aroundin there (a random nutplate). The engine cowlings are off and the plugwires are dangling willy-nilly, since I'm replacing the cooling eyebrows withthe new set that I have. The front seat bulkhead is torn out; I'm rebuildingit with a new one, along with Mike Cuy-style rudder stops and an extra brace acrossthe front of it to keep it from ever ungluing again when I "exercise" therudder bar to its full extents in a crazy crosswind.!> The turn and bank is out of the panel for overhaul. The braided flex fuelline from the shutoff valve to the gascolator is out of the airplane, to be replacedwith aluminum tubing. The aileron control cables are dangling in the cockpit.The ELT battery is out of date and needs to be replaced. The gear legsneed touch-up paint, as do two fabric repair patches at the lift strut attachpoints (still in pink). Gaaa-!!! Will this thing ever fly again? Will theengine even start? Poor Scout!!!> > --------> Oscar Zuniga> Medford, OR> Air Camper NX41CC "Scout"> A75 power> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 908#403908> > > > > > > > > > ________________________________________________________________________________Date: Thu, 4 Jul 2013 16:55:48 +0000 (UTC)
