Pietenpol-List: big wire wheels
Hello Vasek,As Don wrote, there have been quite a few Pietenpols with split landing gearand wire wheels. I have always felt the combination of wire wheels with thesplit gear is beautiful. Tall wheels are very nice on rough fields andpotholes.As Mikee wrote, the two main wire wheel sizes are 19 inches and 21" (notsure what that is in metric). These dimensions refer to the diameter of thewheel rim, NOT the tire itself. Most UK piets use 19 inch diameter rims andI believe G-BUCO does as well.I have the larger size, but the only reason I can see in going with them isthat you like how the larger wheel looks. Wire wheels with brakes arepretty heavy, and a 19 inch wheel is a few pounds lighter and a bit lessdraggy.Most people using wire wheels modify a motorcycle wheel. Because motorcyclewheels are not designed to withstand side loading, most people build a widerhub, with six inches being fairly common. Douwe________________________________________________________________________________
Pietenpol-List: Re: big wire wheels
Original Posted By: "Vasek"
The pictures of the landing gear on Westcoastpiet offer a nice detail. It lookslike there are some 19" and 21" wheels or rims available from motorbikes, soI will loo around and buy some.--------My production of WW1 propellers, trophies and constructions:Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: big wire wheels
You are right, the reason why I choose the wire wheels is just because I like theirlook and they simply fit on the plane.I will look at some shops for used motorcycle wire wheels with 19" in diameter.--------My production of WW1 propellers, trophies and constructions:Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
