Pietenpol-List: Speaking of outdated stuff? Center section fuel tanks
Original Posted By: Brian Kenney
Scott Knowlton-your new nose fuel tank looks great! Way to go.Speaking of outdated items and things that could be considered unsafe or obsolete----let us rethink Bernie's putting fuel up in thewing right over the passenger and pilot in a Pietenpol. Is this wise? Is it safe? Is there a better way to do this? YES! Just tryingto become a free thinker here and not tied to any dated ideas or products. Now where are those old oatmeal containers for my newwing leading edge?Install your fuel tank in the nose.- You don't have to get up on a ladder to fill the tank.-You don't have to run long fuel lines to the firewall.-You don't have to worry about spilling fuel into the cockpits if you overfill the tank then smell it for the next 20 minutes into your ride or flight.-Your CG will benefit because Pietnepols are notoriously tail-heavy (especially with our full-figured girl figures!)-You can run a really short fuel line from the nose fuel tank to the gascolator---and in my case I used a flexible braided line which works fine.-How much fuel CAN you really fit in that wing tank anyway??? Not much right? Comfortable for x-country?? Not really. Need a header or nose tank anyway? Usually.-A nose tank (in my case I hold 17 gallons) can hold MUCH more fuel than a Pietenpol center section tank.-You can use that wing center section space for dry stuff won't leak out if you crash like your sleeping bag, your pillow, some rags, a tent, your tie-downs, a few spare tools, quarts of spare oil.....-The nose tank can be filled without a ladder or climbing up all over the airplane where you risk not only falling but damaging your airplane.-in the event of an accident there will be no fuel overhead to spill onto you or your passengers.Bernie had lots of great ideas when he designed the Pietenpol and I admire his design skills that still bring us the joy of simple, safe, economical flight today but his centersection wing tank isn't one I would recommend.Mike C.Ohio[cid:image001.jpg(at)01CF4759.7E0BFCD0]________________________________________________________________________________
Michael, I like your article on fuel tanks. My tank is in the center section and is 20 gallons. It works great for my corvair but I am changing to a C85, so how much head pressure do I need if I decide to install a nose tank? Sent from my iPhoneOn Mar 24, 2014, at 12:06 PM, "Cuy, Michael D. (GRC-RXD0)[Vantage Partners, LLC]" wrote:> Scott Knowlton=94your new nose fuel tank looks great! Way to go. > > Speaking of outdated items and things that could be considered unsafe or obsolete----let us rethink Bernie=99s putting fuel up in the> wing right over the passenger and pilot in a Pietenpol. Is this wise? Is it safe? Is there a better way to do this? YES! Just trying> to become a free thinker here and not tied to any dated ideas or products. Now where are those old oatmeal containers for my new> wing leading edge?> > Install your fuel tank in the nose. > > - You don=99t have to get up on a ladder to fill the tank.> -You don=99t have to run long fuel lines to the firewall.> -You don=99t have to worry about spilling fuel into the cockpits if you overfill the tank then smell it for the next 20 minutes into your ride or flight.> -Your CG will benefit because Pietnepols are notoriously tail-heavy (especially with our full-figured girl figures!)> -You can run a really short fuel line from the nose fuel tank to the gascolator---and in my case I used a flexible braided line which works fine.> -How much fuel CAN you really fit in that wing tank anyway??? Not much right? Comfortable for x-country?? Not really. Need a header or nose tank anyway? Usually. > -A nose tank (in my case I hold 17 gallons) can hold MUCH more fuel than a Pietenpol center section tank.> -You can use that wing center section space for dry stuff won=99t leak out if you crash like your sleeping bag, your pillow, some rags, a tent, your tie-downs, a few spare tools, quarts of spare oil..> -The nose tank can be filled without a ladder or climbing up all over the airplane where you risk not only falling but damaging your airplane.> -in the event of an accident there will be no fuel overhead to spill onto you or your passengers.> > Bernie had lots of great ideas when he designed the Pietenpol and I admire his design skills that still bring us the joy of simple, safe, economical flight today but his center> section wing tank isn=99t one I would recommend.> > Mike C.> Ohio> > > > > > ________________________________________________________________________________
Re: Pietenpol-List: Speaking of outdated stuff? Center section fuel tanks
Original Posted By: Lion Mason
=0A=0A=0A=0A=0A=0A=0A=0AScott Knowlton=97your new nose fuel tank looks great! Way to go. =0A=0A =0ASpeaking of outdated items and things that could be considered unsafe or obsolete----let us rethink Bernie=92s putting fuel up in the=0Awing right over the passenger and pilot in a Pietenpol. Is this wise? Is it safe? Is there a better way to do this? YES! Just trying=0Ato become a free thinker here and not tied to any dated ideas or products. Now where are those old oatmeal containers for my new=0Awing leading edge?=0A =0AInstall your fuel tank in the nose. =0A =0A- You don=92t have to get up on a ladder to fill the tank.=0A-You don=92t have to run long fuel lines to the firewall.=0A-You don=92t have to worry about spilling fuel into the cockpits if you overfill the tank then smell it for the next 20 minutes into your ride or flight.=0A-Your CG will benefit because Pietnepols are notoriously tail-heavy (especially with our full-figured girl figures!)=0A=0A-You can run a really short fuel line from the nose fuel tank to the gascolator---and in my case I used a flexible braided line which works fine.=0A=0A-How much fuel CAN you really fit in that wing tank anyway??? Not much right? Comfortable for x-country?? Not really. Need a header or nose tank anyway? Usually. =0A=0A-A nose tank (in my case I hold 17 gallons) can hold MUCH more fuel than a Pietenpol center section tank.=0A=0A-You can use that wing center section space for dry stuff won=92t leak out if you crash like your sleeping bag=2C your pillow=2C some rags=2C a tent=2C your tie-downs=2C a few spare tools=2C quarts of spare oil=85..=0A-The nose tank can be filled without a ladder or climbing up all over the airplane where you risk not only falling but damaging your airplane.=0A=0A-in the event of an accident there will be no fuel overhead to spill onto you or your passengers.=0A=0A =0ABernie had lots of great ideas when he designed the Pietenpol and I admire his design skills that still bring us the joy of simple=2C safe=2C economical flight today but his center=0Asection wing tank isn=92t one I would recommend. =0A =0AMike C.=0AOhio=0A =0A =0A=0A =0A =0A 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: Re: Pietenpol-List: Speaking of outdated stuff? Center section fuel tanksvs. nose tanks on a Pietenpol?
