Re: Pietenpol-List: Current draw of a White-Rodgers continuous duty DC
Original Posted By: Ned Lebens
In preparing for a long cross country, I am try to determine totalelectrical power needs for my system (I dont have onboard chargingcapability).Many aircraft, including my Piet, have a White-Rodgers (P/N 70-11126-5)continuous duty DC contactor that is used as a master switch relay. Ithink they are common on Pipers and Cessnas.Does anyone know what the current draw is on the low amperage side? Thatis, how much current is drawn to energize the coil in order to close theheavy-amperage contacts? I guess I could hook up a meter across the masterswitch poles, flip the switch, and see what I amperage reads on the meter,right?Thanks,Jeff--Jeffrey H. Boatright, PhD, FARVOProfessor of OphthalmologyEmory University School of MedicineOn 6/3/14, 3:42 PM, "aerocarjake" wrote:>>>Thanks....>>Data and knowledge of those who came before us is very helpful. Hope to>not ever be part of one of these accident lists...!>>J>>-------->Jake Schultz - curator,>Newport Way Air Museum (OK, it's just my home)>>>Read this topic online here:>>http://forums.matronics.com/viewtopic.p ... ______This e-mail message (including any attachments) is for the sole use ofthe intended recipient(s) and may contain confidential and privilegedinformation. If the reader of this message is not the intendedrecipient, you are hereby notified that any dissemination, distributionor copying of this message (including any attachments) is strictlyprohibited.If you have received this message in error, please contactthe sender by reply e-mail message and destroy all copies of theoriginal message (including attachments).________________________________________________________________________________Date: Tue, 3 Jun 2014 15:21:19 -0500Subject: Re: Pietenpol-List: Current draw of a White-Rodgers continuous duty DCcontactor/solenoid/relay
Thanks Ned!Sent from an iPhone with a spelling problemOn Jun 3, 2014, at 4:24 PM, "Ned Lebens" > wrote:Looks like the coil is 16 ohms at 25C if the data in the link below is to be believed. Apparently 70-11126-5A is Stancor 70-918. Current would be your battery voltage divided by 16 ohms, or about 0.78A.http://www.texasindustrialelectric.com/ ... ______This e-mail message (including any attachments) is for the sole use ofthe intended recipient(s) and may contain confidential and privilegedinformation. If the reader of this message is not the intendedrecipient, you are hereby notified that any dissemination, distributionor copying of this message (including any attachments) is strictlyprohibited.If you have received this message in error, please contactthe sender by reply e-mail message and destroy all copies of theoriginal message (including attachments).________________________________________________________________________________Date: Tue, 3 Jun 2014 15:45:38 -0500Subject: Re: Pietenpol-List: Current draw of a White-Rodgers continuous duty DCcontactor/solenoid/relay
