Pietenpol-List: Gear
My 2 cents on the vertical seat base in the photo above marked 3/22/2010:It is a structural mistake to cut it out like that. The plans show this as a 5.5"or 6" tall 23" wide sheet. Yes it has a hole in it for the control tube, butit has a continuous side to side stick at the front of the seat that is cutout in the photo. .If built to plans, even with the hole in it, the 6" plate is a shear web that spreadshalf the seat loads all the way to the sides of the plane. Built in thephoto, weight on the seat will be allowed to bend the bottom of the fuselageat the center line. Don't take my word for this, just ask Jack Phillips aboutthis..Wood structures work because you glue the all together and they become "monolithic."Well made glue joins do a great job spreading loads. deciding to make awood panel removable essentially prevents it from pulling its share of the loadand supporting adjacent panels. Having a seat bottom that isn't glued in isa mistake, and combining it with a structurally cut 6" front support compoundsthe issue..Not flying aerobatics? Go ask anyone with a G meter in their plane where the needlepoints after a really hard landing, and that applies to planes with 9" ofsuspension travel and regular aircraft tires with several inches of sidewalldeflection. Just because it holds a big guy in the workshop means nothing onthe flight line. .If you don't know structures, resist offering guidance to other builders on howto modify load bearing elements of their planes. -ww.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Gear
Re: Pietenpol-List: Gear
Well after much fitting, remaking of parts and installing my gear legs are on and cross cabled. A very satisfying day. My wheels are almost complete and ready for install as well. And "no" I didn't install my turtledeck on the underside of the belly. It's just sitting in a convenient spot out of the way. Very motivating.Scott KnowltonBurlington On. Sent from my iPhone________________________________________________________________________________Date: Fri, 5 Sep 2014 13:17:54 -0600Subject: Re: Pietenpol-List: Gear
Pietenpol-List: Re: Gear
Original Posted By: "aviken"
Scott,Don't leave your plane in this position too longer, nor scratch it's belly, itmay learn to like this position!Beautiful work!Ray Krause,Building SkyScout.Sent from my iPad> On Sep 5, 2014, at 12:08 PM, Scott Knowlton wrote:> > Well after much fitting, remaking of parts and installing my gear legs are onand cross cabled. A very satisfying day. My wheels are almost complete andready for install as well. And "no" I didn't install my turtledeck on the undersideof the belly. It's just sitting in a convenient spot out of the way. > Very motivating.> > Scott Knowlton> Burlington On. > > > > > > > Sent from my iPhone________________________________________________________________________________Subject: Pietenpol-List: Re: Gear
Avken,Thanks for posting. This SCAM is NOT limited to any one site / entity and is notonly a Barnstormers issue - This SCAM is very well documented in many SCENARIOS.It is a very popular e-mail based scam.Thank you for alerting our members AvKen.--------Bob 'Early Builder' DewenterDayton OHRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Gear
Original Posted By: woodflier
Looks FABULOUS!--------Bob 'Early Builder' DewenterDayton OHRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 5 Sep 2014 20:04:05 -0400
RE: Pietenpol-List: Gear
Congratulations, Scott!You're through what was for me the hardest part of the entire airplaneproject.Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
