Pietenpol-List: Anyone build the single piece wing?
Original Posted By: "Pocono John"
Setup a temporary workbench and table in the hangar to start the overhaul process on this A-65-8 that I picked upin Michigan last fall. These sure are cool little, powerful, sturdy little motors. This one feels much heavier than theoriginal I overhauled 16 years ago.......Mike C.Ohio[cid:image001.jpg(at)01CFCDDD.F07A09F0]________________________________________________________________________________Subject: Pietenpol-List: Anyone build the single piece wing?
Re: Pietenpol-List: A-65 major overhaul begins
Just curious if you'd do it again, and how you mounted the wing; and any otherissues. I don't yet know which one to build, so I'm building only the ribs thatare common to both.--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: A-65 major overhaul begins
Re: Pietenpol-List: Santiago Morete's panel
Original Posted By: Amsafetyc
Hello, Pietenpolers;I just got this info from the fellow who is getting the Vi Kapler tail hinge castingsset up for me, but that's a different subject. If anyone is looking fora Cloudcars prop for their Corvair Piet, it sounds like Jay Anderson is tryingto get out of the prop business and has about a 6 month delay getting propsout, so you may want to jump on this:>He does have a few corvair piet props on hand if you know anybody>looking. Most of his props are in the $1000 range all ready to go or >you can buy one fresh off his carving machine and finish it yourself.>Jay can be reached at 1-325-356-2810.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Santiago Morete's panel
Pietenpol-List: Re: Anyone build the single piece wing?
Original Posted By: "biplan53"
Great looking panel, nice work Santiago !Sent from my iPhone> On Sep 9, 2014, at 9:15 PM, santiago morete wrote:> > Thank you Mike! I'm glad you like it!> Jake, I just need to find a decent one> Saludos!> > Santiago> > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> ________________________________________________________________________________Subject: Pietenpol-List: Re: Anyone build the single piece wing?
Pietenpol-List: Re: NX992WD "Finished"
Two friends of mine worked together and built 2 one piece wings. Just looking atthem and I see they take a huge amount of room in the shop. Trying to move themis a 2 man job. If you have plenty of room and someone that is going to helpyou it might not be undo able. Also it takes a very long work bench. Not tryingto be too negative just trying to give a heads up.--------Building steel fuselage aircamper.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: NX992WD "Finished"
Michael, when you get to fly her I'd really like to know if the baffles work out.I just do not like the eyebrow baffles.--------Building steel fuselage aircamper.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 12 Sep 2014 03:49:11 -0700
Re: Pietenpol-List: Re: NX992WD "Finished"
Subject: Re: Pietenpol-List: Re: NX992WD "Finished"
Pietenpol-List: Re: Progress in Pryor...
Mike, the tank is a fairly simple square box with an airfoil contoured top. Wantedto use it as the top and avoid additional covering/paneling. Then pop rivetsand LOTS of Proseal!Here are links to a couple pictures. LOTS more on Westcoastpiet.comhttp://westcoastpiet.com/images/Jim%20Markle/images/tank2003_0131_094007AA.JPGhttp://westcoastpiet.com/images/Jim%20Markle/images/fueldrn2003_0220_221437AA.JPGCongratulations again on your accomplishment!Jim in rainy/cold Pryor.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 12 Sep 2014 06:44:51 -0700
