Pietenpol-List: Re: I left
It just dawned on me...The full size rib drawing is apparently an improved wing from the one shown onsheet 5. The front nine inches of the full size improved rib is quite more narrowerthan page 5, and the very tip of the leading edge will be at least halfan inch lower than sheet 5.That would affect the chord line. Seems to me that no matter what rib is used,a builder would have to draw the chord line and measure that off the longitudinalaxis to achieve the required angle (affects cabanes length).The remainder of the plans may be based of the old rib (page 5) and not factorthe changes of the new rib. I expect some measurements to be off because of this.--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: I left
Re: Pietenpol-List: a few motivational Piet pictures
Original Posted By: Amsafetyc
So glad you were able to find enjoyment in the time you did spend on the Pietenpol.It will always carry your spirit. Sorry you could not carry it forward. Youwll always be part of this group of souls who are taking flight via historyand camaraderie....!--------Jake Schultz - curator,Newport Way Air Museum (OK, it's just my home)Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: a few motivational Piet pictures
Nice job Mike Sent from my iPhone> On Aug 20, 2014, at 11:29 AM, "Cuy, Michael D. (GRC-LME0)[Vantage Partners, LLC]" wrote:> > > Earl Brown with wife Katrina (from PA) try out Piet for size.> > > > Checkout that very cool use of Larry William=99s center section for rags/supplies! (Douwe to right of Larry)> > > > > > Kevin=99s wife Shelley prepares Curt Merdan=99s daughter for a ride at Brodhead. Matt Paxton from VA gives a ride to John Recine=99s Cousin Faith at Brodhead.> > > > Gentleman Jack Phillips and Greg Cardinal at Brodhead. Kevin Purtee, Ryan Mueller, Gary Boothe at Brodhead a few years ago.> > > > Dan Helsper at Brodhead Jack and Susan Textor with Kevin Purtee, center.> > > > ________________________________________________________________________________Date: Tue, 16 Sep 2014 05:49:07 -0700
Thank you Douwe,The person who bought it is in the group. And I will be here, in the feauture Iam going to build something else, not a Piet, something easier, may be my firstidea... not so beautifull, a little .. selfish?.. (just for one), etc...Regards,--------Mario GiacummoPhotos here: http://goo.gl/wh7M4Little Blog : http://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: I left
It's hard to see him go, yes it is. But reality is reality, and as Cortes saidsometime you have to "burn the ships" and go ahead.I hope to see it flying soon, it will be a great reward for us.Hasta luego.--------Mario GiacummoPhotos here: http://goo.gl/wh7M4Little Blog : http://vgmk1.blogspot.comRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
