Original Posted By: "oldbird"
Subject: Re: Pietenpol-List: Re: Hard Starting Cont. EnginesPlease forgive my ignorance. Is this the "Bendix luch box"=8B?SemihOn Fri, Aug 26, 2016 at 6:12 AM, Ray Krause wrote:> raykrause(at)frontiernet.net>>> Louie,>> So how do you check the spark on Eismann A-4 mags to make sure they are> running properly? Does anyone overhaul them?>> Thanks,>> Ray Krause> A-65-8, Eismann mags, impulse on the left.>> Sent from my iPad>> > On Aug 25, 2016, at 5:53 PM, Louie Bakrevski > wrote:> >> lupchob(at)hotmail.com>> >> > Oscar> > Let's clarified that -8 cases only came with Bendix lunch box mags,> eisman mags, case mags (they belong on orange ) tractors , s-200 or s-20> mags. All of this mags ONLY have impulse coupling on left side. Right side> non impulse mag. Slick mags have a impulse on BOTH mags.> > All of -8 mags and -9 mags are right turning mags. Lunch box mags do NOT> have a impulse coupling on both mags, so you are starting at around 30> degrees of BTC. You have to swing the prop with authority wood props could> swing back. Eisman Bendix S-20 or 200 only have in pulse on left mag .> Should started on left mag only. Dash 12 cases C-75 ,C-85 C-90 could> usually will have impulse coupling on both sides. If you have impulse> coupling on both sides should be started on both mags. Now if you have push> to start Bendix switch you have to make shure it's set up wright . There is> jumper , needs to be in right position. If you need more information you> have to entice me wit few MGD. ( mighty good diner). Louie.> > Ps a have a ton of small continental pars and mags.> >> > Sent from my iPad> >> >> On Aug 25, 2016, at 10:20 AM, taildrags wrote:> >>> taildrags(at)hotmail.com>> >>> >> OK, so this is from the A&P who overhauled my A75:> >>> >> "Continentals, if equipped with Impulse Couplers, almost always have> them on both mags. If you buy Slick magneto kit for an A series engine,> the kit will come with two impulse coupled mags. If one wanted to install> their mags piecemeal, you could mount mags with no impulse, the impulse on> either the left or right mags, or on both.> >>> >> Lycoming engines come with the impulse on the left mag only. The> impulse in the mags for a Lycoming engine takes up a bit of space, so> Lycoming adds a spacer onto the left magneto mount to accommodate the> installation of an impulse coupling. A spacer could also be added to the> right side if one so desired, but would also require longer studs for> mounting the second impulse coupled magneto.> >>> >> I've never seen anyone add a second impulse coupled mag onto a> Lycoming, but on both A and C series Continentals, dual impulse coupled> magnetos is the way they are typically configured. "> >>> >> --------> >> Oscar Zuniga> >> Medford, OR> >> Air Camper NX41CC "Scout"> >> A75 power, 72x36 Culver prop> >>> >>> >>> >>> >> Read this topic online here:> >>> >>
http://forums.matronics.com/viewtopic.p ... 890#459890> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >>>=======================================================>>-- Semih Oksay________________________________________________________________________________Subject: Pietenpol-List: Re: Hard Starting Cont. Engines
