Page 3 of 4
Re: N34KP's rebuild
Posted: Tue Sep 10, 2024 3:14 pm
by Richard Roller
I have to scarph 2 pieces together for the floor board. Here goes nothing!
Re: N34KP's rebuild
Posted: Tue Sep 10, 2024 4:50 pm
by taildrags
Wish I lived closer to you. I have the plywood that you'd need without having to scarf it. I have the plywood for the sides, too. Leftovers from the Piet project that Corky started but never finished.
Re: N34KP's rebuild
Posted: Tue Sep 10, 2024 5:32 pm
by Richard Roller
I appreciate the thought, Oscar. I have the sides and everything else. I just didn't have the 1/4" for the floor. I ordered 2 pieces of 1/4" x 2 x 4 because it saved me a bunch of shipping cost.
Speaking of shipping cost. I'm doing a road trip to Wicks tomorrow, for lift struts. It's 5 hours away. Shipping for the struts, from one side of Missouri to the other, was going to be $280! Over half of the price of the struts!
Re: N34KP's rebuild
Posted: Tue Sep 10, 2024 5:35 pm
by Richard Roller
The second one (left) turned out nicer than the first. I'll clean up the first one and glue tomorrow.
Re: N34KP's rebuild
Posted: Thu Sep 12, 2024 1:59 pm
by Richard Roller
Attempting to glue the two pieces together.
Re: N34KP's rebuild
Posted: Thu Sep 12, 2024 3:55 pm
by taildrags
"Do or not do. There is no try." -Yoda
Re: N34KP's rebuild
Posted: Thu Sep 12, 2024 9:52 pm
by Richard Roller
No X wings here! In a swamp, or otherwise!
Re: N34KP's rebuild
Posted: Fri Sep 20, 2024 3:52 pm
by Richard Roller
I was mulling over a change to the engine mount brackets at the firewall. I've decided to increase the brackets bolt patterns by one bolt, both horizontally and vertically. So I pulled the existing corner gussets off and I'm gluing new ones on sized to the new bolt pattern. This is in case I decide to change the engine installation down the road.
Re: N34KP's rebuild
Posted: Sat Sep 21, 2024 5:22 pm
by taildrags
Now there's a forward-thinking man...
Re: N34KP's rebuild
Posted: Sun Sep 22, 2024 12:58 pm
by Richard Roller
Years ago I redrew the steel tube drawings stretched to the long piet length. My thought was to use a 60° V6 on it. I'll probably never built it. But who knows, a V6 on 34KP?
Re: N34KP's rebuild
Posted: Fri Sep 27, 2024 8:26 pm
by Richard Roller
I picked up a piece of white ash today to make the engine bearers and landing gear stations pieces.
Re: N34KP's rebuild
Posted: Mon Sep 30, 2024 3:24 pm
by taildrags
...and who doesn't love a nice piece of wood? Especially if it has an airplane part inside it!
Re: N34KP's rebuild
Posted: Tue Oct 01, 2024 7:15 pm
by Richard Roller
I forced myself to do something today on the Piet. I cut out the ash cross members for the landing gear and started the glueing of the forward cross piece. The floor board is ready to glue on as soon as I get the rear one in.
Re: N34KP's rebuild
Posted: Wed Oct 02, 2024 9:22 am
by Richard Roller
Forward cross piece glued in.
Re: N34KP's rebuild
Posted: Thu Oct 03, 2024 7:48 am
by Chuck in Indiana
Thanks for taking the time to document this. It will be a good resource when I get there.
Re: N34KP's rebuild
Posted: Thu Oct 03, 2024 12:17 pm
by Richard Roller
The rear cross piece is in and I'm fitting the floor board.
Re: N34KP's rebuild
Posted: Thu Oct 03, 2024 3:18 pm
by taildrags
Well come on, Richard... floor it!
Re: N34KP's rebuild
Posted: Tue Oct 08, 2024 7:33 am
by Richard Roller
Glued the floor board on just now. No help, that was a busy 30 minutes!
Re: N34KP's rebuild
Posted: Tue Oct 08, 2024 11:32 am
by taildrags
They don't call it "working time" for nothing. Spread and smooth on all glue areas for all you're worth... you can feel it starting to get a little tacky... get it into place... lift and shift, align and clamp, unloosen and readjust... hurry! Hurry!. Then it's past the point of no return and you just have to clamp and staple and figure you can shave any little overhangs and squeeze-out later. Don't you love it?
Re: N34KP's rebuild
Posted: Tue Oct 08, 2024 5:14 pm
by Richard Roller
The glue up on the floorboard worked well. I've planed the edges flush and removed the staples. Several staples broke while trying to remove them. Glued in I guess. I'll have to think about this a little.
Re: N34KP's rebuild
Posted: Mon Oct 14, 2024 11:37 am
by Chuck in Indiana
I wonder if you could heat the staple with a soldering iron to soften the epoxy locally?
Re: N34KP's rebuild
Posted: Mon Oct 14, 2024 12:42 pm
by Richard Roller
I'm going to ignore the broken staples. They broke off flush with the plywood, and I can't get hold of them short of digging away some of the plywood.
Re: N34KP's rebuild
Posted: Thu Nov 07, 2024 3:01 pm
by Richard Roller
Slow progress. I've flip the fuselage back upright and started the last gussets. Currently glueing the last two inboard splice doublers.
Re: N34KP's rebuild
Posted: Mon Nov 11, 2024 3:11 pm
by Richard Roller
Re: N34KP's rebuild
Posted: Wed Nov 13, 2024 9:09 pm
by Richard Roller
Re: N34KP's rebuild
Posted: Wed Nov 13, 2024 10:59 pm
by taildrags
It's a wonder that the entire world isn't held rigidly in place with gussets. Got to have them!
Re: N34KP's rebuild
Posted: Tue Nov 19, 2024 12:21 pm
by Richard Roller
I decided to block the corners of the firewall station truss.
Re: N34KP's rebuild
Posted: Thu Nov 21, 2024 2:12 pm
by Richard Roller
Re: N34KP's rebuild
Posted: Thu Nov 21, 2024 3:05 pm
by taildrags
I'll bet that fuselage frame is stiffening up nicely, what with the blocking and crosspieces and gussets getting installed. One of the most comforting things about a Piet is the robustness of its basic structural 'cage'.
Re: N34KP's rebuild
Posted: Thu Nov 21, 2024 3:21 pm
by Richard Roller
Yes. It's getting pretty sturdy even without the side plywood.
Re: N34KP's rebuild
Posted: Tue Dec 03, 2024 8:22 am
by Richard Roller
While test fittings controls today, I discovered the aileron torque tube between cockpits was bent a little in the crash. Always something.
Re: N34KP's rebuild
Posted: Mon Dec 16, 2024 1:48 pm
by Richard Roller
Test fitting rear cabane attach fittings in the upper longerons. Nice fit.
Re: N34KP's rebuild
Posted: Mon Dec 16, 2024 4:14 pm
by Richard Roller
Test fitting cabane attach fittings in the upper longerons. Nice fit.
Re: N34KP's rebuild
Posted: Wed Feb 19, 2025 12:03 pm
by Richard Roller
Test fitting the front cockpit seat back.
Re: N34KP's rebuild
Posted: Thu Feb 20, 2025 8:16 pm
by Richard Roller
I glued a wedge into the area of the seat back to the gear/liftstrut carry though. Also cutout the torque tube opening.
Re: N34KP's rebuild
Posted: Thu Feb 20, 2025 11:11 pm
by taildrags
Richard; the area that I had some problems with over the years that I flew N41CC was the front seat's front face vertical support plywood. On more than one occasion it got kicked by the pilot hard enough to break the plywood free (not by me though). I finally ended up tearing out the entire assembly including the passenger's seat bottom, which didn't have adequate uprights to hold it up, in my opinion. Especially as I had a passenger over 200 lbs get in and out of the front by stepping onto the seat. It didn't give under his weight and strain to climb in, but I didn't want it to. For the front face plywood, I added a block outside the front face of it, secured to the floor.
Re: N34KP's rebuild
Posted: Fri Feb 21, 2025 1:12 pm
by Richard Roller
Re: N34KP's rebuild
Posted: Sat Feb 22, 2025 11:32 am
by Richard Roller
Re: N34KP's rebuild
Posted: Sat Feb 22, 2025 4:43 pm
by taildrags
I see that little wedge shim filler at the bottom
Nice work.
Re: N34KP's rebuild
Posted: Fri Mar 07, 2025 1:47 pm
by Richard Roller
Re: N34KP's rebuild
Posted: Mon Apr 07, 2025 9:08 am
by Richard Roller
I've been mentioned on the radio! I donated this morning to my local Kansas Public Radio station during their fund drive. I mentioned (online donation) that I listen to the classical broadcast while rebuilding my airplane in the dining room. They used it on air, wondering if it was a model or what. They emailed me about it. I described the Piet, the crash, and the rebuild. I sent them pictures. So more on the crash and plane and rebuild on the radio. I'm a celebrity!
Re: N34KP's rebuild
Posted: Mon Apr 07, 2025 10:57 am
by taildrags
Richard; you became a celebrity the day you acquired three four kilo papa and began your Pietenpol journey. But hey, there's nothing wrong with a little bit of publicity. Back when Mr. Pietenpol first flew his Air Camper, television was just becoming commercially viable, so your radio interview this morning was perfectly in keeping with the 1929 style of news stories.
Re: N34KP's rebuild
Posted: Sat Apr 12, 2025 7:46 am
by Richard Roller
A test fit of the control torque tube after cutting out the bent part. The new tube is just tack welded at the moment. Nice fit and no binding (yet) when I move it left to right. It appears to have bent where it hit the rudder bar mount when the front end collapsed in the crash. There is a nice dent in the tube where it hit the rudder bar pivot bolt head.
Re: N34KP's rebuild
Posted: Fri Apr 18, 2025 4:48 pm
by Richard Roller
I finished welding the repair into the aileron torque tube yesterday. Today I drilled the mounting holes, using a guide block and backup wood blocks.
Re: N34KP's rebuild
Posted: Fri Apr 18, 2025 5:40 pm
by taildrags
Looks like you're going about it the right way, which is "do it right the first time and you won't have to do it again". Steady as she goes!
-Oscar Zuniga
Medford,OR
Re: N34KP's rebuild
Posted: Sat Apr 19, 2025 4:22 pm
by Chris_899DP
Looking good Richard! Haven't seen any FB updates on your rebuild in ages glad to see your still hard at it!
Chris
Re: N34KP's rebuild
Posted: Sun May 04, 2025 3:14 pm
by Richard Roller
Okay. I've been in Ireland on a memorial trip for my late wife, Lisa. I promise to get restarted on 34KP when I get home.
Re: N34KP's rebuild
Posted: Sun May 18, 2025 3:51 pm
by Richard Roller
Test fit of the rudder bar and aileron/elevator controls.
Re: N34KP's rebuild
Posted: Sun May 18, 2025 11:33 pm
by taildrags
It looks like an Air Camper rudder bar
-Oscar Z.
Re: N34KP's rebuild
Posted: Tue Jun 17, 2025 1:17 pm
by Richard Roller
Over 23 years of flying N34KP was damaged a couple of times when the copilots seat front plywood support was kicked. I've decided to reinforce the edges during the rebuilt. We'll see if this helps. It is much stiffer. Of course, I may have made it easier to kick off the glue line!
