Original Posted By: baileys(at)ktis.net (Robert M. Bailey)
I need the sizes of the wood parts for all the Piets fusilage wingstailfeathers and everything else. Also the amount of wood I will needsuch as how much wood and sizes are in the fusilage and everything else.Emelita W________________________________________________________________________________
Pietenpol-List: Sizes of wood parts for.
Pietenpol-List:
Doug Hunt wrote:> Hope i'am sending this to the correct address.I'am wondering if anyone> has> a part# for the john deere sring used for the tailwheel,that i have> heard /> read of ???> I am building a corvair powered piet with 60" warp drive prop.> Thanks for now Doug Hunt...________________________________________________________________________________
Pietenpol-List: Re: Sizes of wood parts for.
Original Posted By: Doug Hunt
Emily Williamson wrote:> > I need the sizes of the wood parts for all the Piets fusilage wings> tailfeathers and everything else. Also the amount of wood I will need> such as how much wood and sizes are in the fusilage and everything else.> I'm currently going through the process of figuring this out for thewings. Since I don't have the best place to store lumber it will kindof be on an "as needed" basis instead of all at once. In any case I'llbe glad to share whatever information I come up with. It will probablybe after Brodhead before I start ordering wood.Bob Bailey________________________________________________________________________________
Pietenpol-List: RE: Re: Sizes of wood parts for.
Original Posted By: "Craig R. Lawler"
Keep in mind that weight is important. If you look at any of the planes that Berniebuilt all the wood is undersized. He measured to the center of the kerf ofthe blade on the table saw so all dimensions are about 1/16" less than whatis called for on the plans.________________________________________________________________________________
Original Posted By: D.BELLISSIMO(at)littonlsl.com (BELLISSIMO, DOMENIC)
writes:Keep in mind that weight is important. If you look at any of the planes that Bernie built all the wood is undersized. He measured to the center of the kerf of the blade on the table saw so all dimensions are about 1/16" less than what is called for on the plans.Amen, brother. If anybody wants to change Mr. Pietenpol's plans, make thechange toward the lighter side. Everyone wants to make everythingstronger and "better", and oh, by the way, heavier. NOT!!!! Mine camein at 610 pounds the second time around. JimV.________________________________________________________________________________
