Subject: Pietenpol-List: to the hatz buildsrs>About building those wing ribs in 2 weeks. When I started out buildingribs, my intention was to get them made, and off the jig quick.out over again, and found that I could in real tearms build one rib on thejig, and "back side gusset" the yesterday's rib each day.>> I could make one complete rib per day...>> Good airplanes are built slow.>>ocb>>>http://www.mailexcite.com________________________________________________________________________________
Original Posted By: Mike Cunningham
I could make one complete rib per day... Good airplanes are built slow.ocbhttp://www.mailexcite.com________________________________________________________________________________
Pietenpol-List: Re: to the hatz buildsrs
Original Posted By: oil can
Your point is well made and well taken. After further consideration Ifigured that a rib-a-day would probably be more realistic. Wouldn't want todo a rush job, rush jobs always take twice as long! Just want to setreasonable (but aggressive) schedules and then make every effort to stick tothem.-----Original Message-----
Original Posted By: Eli or Robert or Teresa Bozeman
My best intention was to do a set of ribs in two weeks also. The best Idid was 1 rib per day working with aerolite. Lots of small nails etc. Idon't think you want to stress the T-88 glue joints until they are wellset. Realistically, you are likely looking at a month of building. On the upside, when it came to hanging the ribs on the spar, everythingfit exactly. When it came to long bar sanding, there was very littlerequired, maybe 30 minutes per wing. Unless your multiple jigs wereEXACTLY the same, you may pay the time price later.________________________________________________________________________________
Subject: Pietenpol-List: Re: to the hatz buildsrs>This is exactly what I have been doing, too. I travel a lot and built a>case around my jig that holds all my tools and wood, then check it in as>baggage. I'll get the rib glued up with gussets on one side, raise it>off the jig surface just enough to keep it from glueing itself to the>jig, then put on the rest of the gussets the next day. So far I average>about 5 hours per rib, which includes all the cutting, sanding, etc. I>tried pulling the rib out of the jig right after putting on the first>side gussets, but found that sometimes the rib capstrips would try and>twist a bit, and I didn't like that with the glue still wet. Before I>glue on the gussets I start all the little nails, just enough to hold>them upright in the gusset with two of them poking the capstrip so I can>put them back where I had them.>>When I started I was using Weldwood Plastic Resin Glue and it works>well, but I have been experimenting with a polyurethane glue similar to>what Roger Mann uses in his Rag Wing designs. Nice part about it is it>is already mixed, just squeeze it and go, and it handles the cooler>temperatures in the garage better than Weldwood. My test samples showed>better adhesion than Weldwood on prepared and unprepared surfaces,>spruce and birch plywood. It is a funny glue as the squeeze out foams a>bit and expands, but it doesn't hurt anything. I still have to try it>at elevated and cold temps, and make sure it is compatible with varnish>and covering materials, so I can't recommend it, but I'll let you know.>>>oil can wrote:>tearms build one rib on the jig, and "back side gusset" the yesterday's>rib each day.>>>> I could make one complete rib per day...>>>>________________________________________________________________________________
About holding all those little nails, OUCH! I found by using a push buttontype electronic probe clip. I could pick up the nail with the clip, positionit and tap it in with out hitting my thick fingers.Tony Bengalis has a cute trick of placing a handful of nails on a tray andtapping the tray while it is slightly inclined. This aligns all the nailshead end down and makes picking them up even easier. Less heads on the wrongend! ;-)John Mc-----Original Message-----
Just be sure to save the ones with heads on the wrong end, for the other side!Don________________________________________________________________________________
This is exactly what I have been doing, too. I travel a lot and built acase around my jig that holds all my tools and wood, then check it in asbaggage. I'll get the rib glued up with gussets on one side, raise itoff the jig surface just enough to keep it from glueing itself to thejig, then put on the rest of the gussets the next day. So far I averageabout 5 hours per rib, which includes all the cutting, sanding, etc. Itried pulling the rib out of the jig right after putting on the firstside gussets, but found that sometimes the rib capstrips would try andtwist a bit, and I didn't like that with the glue still wet. Before Iglue on the gussets I start all the little nails, just enough to holdthem upright in the gusset with two of them poking the capstrip so I canput them back where I had them.When I started I was using Weldwood Plastic Resin Glue and it workswell, but I have been experimenting with a polyurethane glue similar towhat Roger Mann uses in his Rag Wing designs. Nice part about it is itis already mixed, just squeeze it and go, and it handles the coolertemperatures in the garage better than Weldwood. My test samples showedbetter adhesion than Weldwood on prepared and unprepared surfaces,spruce and birch plywood. It is a funny glue as the squeeze out foams abit and expands, but it doesn't hurt anything. I still have to try itat elevated and cold temps, and make sure it is compatible with varnishand covering materials, so I can't recommend it, but I'll let you know.oil can wrote:tearms build one rib on the jig, and "back side gusset" the yesterday'srib each day.> > I could make one complete rib per day...> >________________________________________________________________________________
Original Posted By: Ed Nolan
>About holding all those little nails, OUCH! I found by using a push button>type electronic probe clip. I could pick up the nail with the clip, position>it and tap it in with out hitting my thick fingers.>Tony Bengalis has a cute trick of placing a handful of nails on a tray and>tapping the tray while it is slightly inclined. This aligns all the nails>head end down and makes picking them up even easier. Less heads on the wrong>end!
>>John McI use a wire brad pusher it looks like a awl and the nail fits in a hole inthe end and the outer sleve slides back when you push the nail in. Robert Roach________________________________________________________________________________
