> cable routing
> cable routing
I made a chase from 6061 al for front hole on the left side and putfrt trottle in same then covered it with same leather that cockpittrim was made of. Its under left longeron and you realy can't tellits there. Also used electronic tack from westack, saves problemswith stiff tack cable ( easer to run 2 wire than that big mechanicaltack )Robert B.---steve(at)byu.edu wrote:>> I just tucked mine up under the upper longeron. Spiral wrapped withsome> nylon cable shield.> > Stevee> > -----Original Message-----Mr.> Carmen A. Natalie> Sent: Thursday, December 03, 1998 8:01 AM> To: Pietenpol Discussion> Subject: cable routing> > > Hi all.> I came across something that isn't really detailed on the plans, and> which every Piet builder seems to do differently. Where are thecables> for tachometers, water temp guage, etc. routed? The plans seem to> indicate that the throttle linkage should go through the left fuselage> side (plywood) and under the fabric to the engine, but no mention of> these other cables. (No throttle in the front 'pit on the original> plans..). It looks like Bernie routed stuff along the former which is> attached to the ply fuselage side.> > I've seen where many builders route all of these cables through the> front 'pit, then hide them with some wood panels. I guess this might> make replacement easier, but still seems to clutter the sides of the> front cockpit. I'd like to avoid having too much 'stuff' hangingout in> the passenger area...> > Any thoughts?> > --> ----------------------> Mr. Carmen A. Natalie> President> CA Natalie Associates, Inc> CANA WebSystems> 100 State Street Suite 1040> Albany, New York 12207> http://www.cana.com> phone 518.436.4932> fax 518.436.4933> ----------------------> > ________________________________________________________________________________
