Subject: Pietenpol-List: 0-290 0n Peit>Hi guys, it been awhile but I got the 0-290 hung on my peit last nite,>now for the plumbing and heat boxs for cabin and carb heat>the engine mount is 9 5/8" long and the wing moved back to the>origenal print specs and my CG works out g>ood on paper, so come spring Super Peit!!!!!!!!!!!!!> HI Eli: How much does the 0-290 weigh, and did you install a starter &altenator. Mike B ( Piet N687MB)>>________________________________________________________________________________
Original Posted By: Eli or Robert or Teresa Bozeman
Hi guys, it been awhile but I got the 0-290 hung on my peit last nite,now for the plumbing and heat boxs for cabin and carb heatthe engine mount is 9 5/8" long and the wing moved back to theorigenal print specs and my CG works out good on paper, so come spring Super Peit!!!!!!!!!!!!!________________________________________________________________________________
Pietenpol-List: Re: 0-290 0n Peit
Original Posted By: Dean Dayton
any peit in Missouri or around southwest?---Eli or Robert or Teresa Bozeman wrote:>> Hi guys, it been awhile but I got the 0-290 hung on my peit last nite,> now for the plumbing and heat boxs for cabin and carb heat> the engine mount is 9 5/8" long and the wing moved back to the> origenal print specs and my CG works out g> ood on paper, so come spring Super Peit!!!!!!!!!!!!!> > > ________________________________________________________________________________
-----Original Message-----
Original Posted By:> Eli or Robert or Teresa Bozeman
the engine turned out to be 243 lb. no starter or altthis is Robert, Eli is my 13 yr old that set up the computor I've got 105 TT on my peit but just wanted more power, then I got agood deal on a runout 0-290 and I doubled my horses for about1500-2000 after selling my 65 cont.Robert B.---Michael Brusilow wrote:>> > -----Original Message-----
> 0-290 0n Peit
Original Posted By: RdwdSgn(at)aol.com
> Subject: 0-290 0n Peit> > > >Hi guys, it been awhile but I got the 0-290 hung on my peit lastnite,> >now for the plumbing and heat boxs for cabin and carb heat> >the engine mount is 9 5/8" long and the wing moved back to the> >origenal print specs and my CG works out g> >ood on paper, so come spring Super Peit!!!!!!!!!!!!!> >> > HI Eli: How much does the 0-290 weigh, and did you install astarter &> altenator.> > Mike B ( Piet N687MB)> > > > > >> >> > ________________________________________________________________________________
