> engines
> engines
The plain truth is, I was sort of hoping that someone else would pick up my idea, cast off several, then I could buy one from him...What I will probably end up doing, is using either a plain 134L jeep flat head, (with an aluminium high compression head,) stripped of the cast iron manifolds etc.+ maybe 4 carbs, and headers. Or just bite the bullet and go with a 4 cyl geo and a commercial re-drive.I might just for kicks look into the aluminium block idea a little longer, as there are commercial foundrys nearby.ocb>From steve(at)byu.edu Sat Jan 2 18:43:23 1999>Received: from adena.byu.edu ("port 2144"@adena.byu.edu [128.187.22.180])> by EMAIL1.BYU.EDU (PMDF V5.2-29 #31181)> with ESMTP id for oilcanbob(at)hotmail.com;>Date: Sat, 02 Jan 1999 20:40:28 -0700>From: jmcnarry(at)techplus.com (John McNarry)>Subject: Re: engines>Sender: Maiser(at)adena.byu.edu>To: Pietenpol Discussion >Errors-to: Steve(at)byu.edu>Reply-to: Pietenpol Discussion >Message-id: >MIME-version: 1.0>X-Mailer: Microsoft Outlook Express 4.72.3110.1 (via Mercury MTS v1.43 (NDS))> (via Mercury MTS v1.43 (NDS))>Comments: Originally To: "Pietenpol Discussion" >X-Listname: >>Hi Oil Can,> I suppose if you could find a foundry to cast a few you might sell>enough to bring down your cost, but then it would probably be an expensive>process to machine and sleeve the blocks. Are you a machinist? My research>shows that a Ford engine ready to fly weighs about 244 lbs. Chech out the>BPA website there are references to Fords putting out a reliable 100 hp!>I started building an Air cooled version of the B engine a while back. I>sawed the cracked watercooled cylinders off just at the bottom of the valve>chamber and was planning to use cylinders of my own design and Deutz>aluminum heads converted to gas. I successfully made one head, but there is>still the problem of cam lobe spacing etc........> Then I stumbled onto an ADC Cirrus engine and the conversion stalled!>Let us know if you continue on this idea, the only Stupid question is the>one thought about but unanswered.>>John Mc>>-----Original Message----->From: oil can >To: Pietenpol Discussion >Date: Tuesday, December 29, 1998 2:08 AM>Subject: engines>>>>I'm about to proove that in this world,,, THERE IS,,, such a thing as a>>stupid question!>>>>I'm still interested in ford model A, or a willys jeep flat head... "go>>devil" engine for my airplane. However the weight of all that cast iron>>bothers me. Does any one in the group know how practical it would be>>to have a one-off casting of a jeep, or ford A engine block done in>>aluminium?>>>>Then one could just put in the origonal parts, + an aluminium head, and>>set it up direct drive. It seems to me that a fellow could build up a>>reasonably powerfull engine, that was close to the origonal, and save>>about 1/2 the weight.>>>>Does anybody have an opinion on this?>>>>I may be just blowing smoke, but if the cost of an aluminium casting was>>close to that of a modern re-drive, it might be still worth it.>>Considering that an auto conversion with re-drive runs about 5000.00>>>>ocb>>>>>>________________________________________________________________________________
