Original Posted By:> > > Andrew.Pietenpol(at)stpaul.com
I must be missing something here. If the VW is putting out 2330rpm at146.5ft-lbs and the C-65 is putting out 2400rpm at 142ft-lbs why can't the vwbe swinging the same size prop? It is running 70 rpm faster but has 4.5 ft lbsmore torque.What we need here is an Impartual Expert to explain.Gordonlpasley wrote:> Certainly I'm no expert either, but the A 65 and VW 65 would not be using> the same prop. The VW prop will be quite a lot shorter. You will have more> thrust with the A 65.> Thanks, Larry Pasley> Carlisle, Arkansas>> ----------> > I wont even pretend to know what I'm talking about, But...> >> > VW engine with psru, 65 hp 65hpx5252/2330rpm=146.5 ft-lbs> >> > C-65 engine direct drive 65 hpx5252/2400rpm=142 ft-lbs> >> > Does this mean that the limiting factor of the 65 hp volkswagon engine> > with psru attached is cooling, or am i missing something about torque?> > I assume that in this situation both would use a nearly equal propeller.> > ocb> >> >> > >From steve(at)byu.edu Thu Jan 7 05:03:05 1999> > >Received: from adena.byu.edu ("port 1074"@adena.byu.edu> > [128.187.22.180])> > > by EMAIL1.BYU.EDU (PMDF V5.2-29 #31181)> > > with ESMTP id for> > oilcanbob(at)hotmail.com;> > >Date: Thu, 07 Jan 1999 08:01:37 -0500> > >From: Michael D Cuy > > >Subject: VW Info> > >Sender: Maiser(at)adena.byu.edu> > >To: Pietenpol Discussion > > >Errors-to: Steve(at)byu.edu> > >Reply-to: Pietenpol Discussion > > >Message-id: > > >MIME-version: 1.0> > >X-Mailer: QUALCOMM Windows Eudora Pro Version 4.1 (via Mercury MTS> > v1.44 (NDS))> > > (via Mercury MTS v1.44 (NDS))> > >Comments: Originally To: "Pietenpol Discussion" > > >X-Listname: > > >> > >> > >> > > Subj: VW Engines> > > Date: Fri, Jul 24, 1998 11:57 AM EDT
