Pietenpol-List: Help, need info
Pietenpol-List: Re: Help, need info
Original Posted By:> mboynton(at)excite.com
Mark, I have mosyt of the Sport Aviations from the 70s. I will look andsee if I have the article. Let you know in about three days.Phil Phillips
If you'll call the EAA and talk with a gentleman namedOwens he has a Sport aviation archive and most backissues of Sport Aviation,example I asked for a listof all back issues that contained articles or featuredPietenpols and what a list I got,boy talk about DATAload, Pietenpols that fly on Kawasakis, Subaru'sradials,steam engines just kidding about that last one! Any how tell him what you want and he'll send youthe Sport Aviation that has the article.-----Original Message-----
Original Posted By:>> > mboynton(at)excite.com
Subject: Pietenpol-List: Re: Help, need info>Phil,>>Thanks. Any help will be greatly appreciated.>>Mark Boynton>Gilbert, AZ>>>> Mark, I have mosyt of the Sport Aviations from the 70s. I will look and>> see if I have the article. Let you know in about three days.>>>> Phil Phillips>>>> ----------
Original Posted By: Phil Phillips
To all:Can any of you provide information about the article or articles in SportAviation that appeared, I believe, in the 70's, about the PSRU designed byBud Rinker, using the gear reduction box from a Type 2 (bus) Volkswagontransaxle. The system is commonly referred to as a Rinker redrive or RinkerPSRU, and can be used to reduce prop speed on the Corvair engine. VerticalSystems, the outfit that markets the plans set for it, seems to have droppedoff of the face of the earth. I've contacted the EAA library, but they wereunable to give me any solid leads. I'm certain that either Bud Rinker hadan article published or that someone else did, about his system. However,EAA is unable to do a search that far back by author name, and none of thetitles they cited mentioned the Rinker PSRU (not directly in the title. I'mcertain the information is there, but I can't seem to locate it. Help!Mark BoyntonGilbert, AZ ________________________________________________________________________________
I tracked Bud Rinker down in Santa Barbara, CA and he referred me to thesefolks, as the interest had dried up and he was retired, so he gave it to them tohandle. Vertical Systems 34 Paradise Road Santa Barbara, CA, 93105 e-mail at vertsys@west.net and a web page at http://www.west.net/~vertsys The plans set is $75.00 plus $2.00 postage, with particular attention toCorvair engine application.Haven't tried any of this for awhile, so can not confirm that they are their anylonger.Warrenmboynton(at)excite.com wrote:> To all:>> Can any of you provide information about the article or articles in Sport> Aviation that appeared, I believe, in the 70's, about the PSRU designed by> Bud Rinker, using the gear reduction box from a Type 2 (bus) Volkswagon> transaxle. The system is commonly referred to as a Rinker redrive or Rinker> PSRU, and can be used to reduce prop speed on the Corvair engine. Vertical> Systems, the outfit that markets the plans set for it, seems to have dropped> off of the face of the earth. I've contacted the EAA library, but they were> unable to give me any solid leads. I'm certain that either Bud Rinker had> an article published or that someone else did, about his system. However,> EAA is unable to do a search that far back by author name, and none of the> titles they cited mentioned the Rinker PSRU (not directly in the title. I'm> certain the information is there, but I can't seem to locate it. Help!>> Mark Boynton> Gilbert, AZ>> _______________________________________________________________________________________________________________________________________
Original Posted By:> > mboynton(at)excite.com
Phil,Thanks. Any help will be greatly appreciated.Mark BoyntonGilbert, AZ > Mark, I have mosyt of the Sport Aviations from the 70s. I will look and> see if I have the article. Let you know in about three days.> > Phil Phillips> > ----------
Original Posted By: Patcoolnet(at)aol.com
Warren,Thanks. The kicker is that Vertical Systems no longer has an internet site,and a phone call results in "that number has been disconnected or is nolonger in service..." Also, they no longer have e-mail (at least not at theaddress we have). Do you know if Bud Rinker will take a call forinformation and if so, how to get ahold of him? Thanks for your help.Mark BoyntonGilbert, AZ> I tracked Bud Rinker down in Santa Barbara, CA and he referred me tothese> folks, as the interest had dried up and he was retired, so he gave it tothem to> handle.> Vertical Systems> 34 Paradise Road> Santa Barbara, CA, 93105> e-mail at vertsys(at)west.net and a web page athttp://www.west.net/~vertsys> The plans set is $75.00 plus $2.00 postage, with particularattention to> Corvair engine application.> Haven't tried any of this for awhile, so can not confirm that they aretheir any> longer.> Warren> > mboynton(at)excite.com wrote:> > > To all:> >> > Can any of you provide information about the article or articles inSport> > Aviation that appeared, I believe, in the 70's, about the PSRU designedby> > Bud Rinker, using the gear reduction box from a Type 2 (bus) Volkswagon> > transaxle. The system is commonly referred to as a Rinker redrive orRinker> > PSRU, and can be used to reduce prop speed on the Corvair engine.Vertical> > Systems, the outfit that markets the plans set for it, seems to havedropped> > off of the face of the earth. I've contacted the EAA library, but theywere> > unable to give me any solid leads. I'm certain that either Bud Rinkerhad> > an article published or that someone else did, about his system.However,> > EAA is unable to do a search that far back by author name, and none ofthe> > titles they cited mentioned the Rinker PSRU (not directly in the title.I'm> > certain the information is there, but I can't seem to locate it. Help!> >> > Mark Boynton> > Gilbert, AZ> >> > _______________________________________________________> ________________________________________________________________________________
Mark, I just checked: they shut down their website in December, and Eric, thesite host, has no forwarding information for them. I have tried in the fast few months to recontact Bud Rinker and there is noanswer at the old number that I had or it is busy for 6-10 hours. Will continueto see what I can do.Warrenmboynton(at)excite.com wrote:> Warren,>> Thanks. The kicker is that Vertical Systems no longer has an internet site,> and a phone call results in "that number has been disconnected or is no> longer in service..." Also, they no longer have e-mail (at least not at the> address we have). Do you know if Bud Rinker will take a call for> information and if so, how to get ahold of him? Thanks for your help.>> Mark Boynton> Gilbert, AZ>>> > I tracked Bud Rinker down in Santa Barbara, CA and he referred me to> these> > folks, as the interest had dried up and he was retired, so he gave it to> them to> > handle.> > Vertical Systems> > 34 Paradise Road> > Santa Barbara, CA, 93105> > e-mail at vertsys(at)west.net and a web page at> http://www.west.net/~vertsys> > The plans set is $75.00 plus $2.00 postage, with particular> attention to> > Corvair engine application.> > Haven't tried any of this for awhile, so can not confirm that they are> their any> > longer.> > Warren> >> > mboynton(at)excite.com wrote:> >> > > To all:> > >> > > Can any of you provide information about the article or articles in> Sport> > > Aviation that appeared, I believe, in the 70's, about the PSRU designed> by> > > Bud Rinker, using the gear reduction box from a Type 2 (bus) Volkswagon> > > transaxle. The system is commonly referred to as a Rinker redrive or> Rinker> > > PSRU, and can be used to reduce prop speed on the Corvair engine.> Vertical> > > Systems, the outfit that markets the plans set for it, seems to have> dropped> > > off of the face of the earth. I've contacted the EAA library, but they> were> > > unable to give me any solid leads. I'm certain that either Bud Rinker> had> > > an article published or that someone else did, about his system.> However,> > > EAA is unable to do a search that far back by author name, and none of> the> > > titles they cited mentioned the Rinker PSRU (not directly in the title.> I'm> > > certain the information is there, but I can't seem to locate it. Help!> > >> > > Mark Boynton> > > Gilbert, AZ> > >> > > _______________________________________________________> >>> _______________________________________________________________________________________________________________________________________
Original Posted By: Thomas E Bowdler
Follow-up: Got in touch with Bud's daughter, who called her Dad. He knows that this guyhas a project of some kind going at the local airport and is going to find himandsee what he can do. Bud apparently no longer has any drawings or data sheets, having sold themtothis guy. Will keep you posted.WarrenWarren Shoun wrote:> Mark,> I just checked: they shut down their website in December, and Eric, the> site host, has no forwarding information for them.> I have tried in the fast few months to recontact Bud Rinker and there isno> answer at the old number that I had or it is busy for 6-10 hours. Will continue> to see what I can do.> Warren>> mboynton(at)excite.com wrote:>> > Warren,> >> > Thanks. The kicker is that Vertical Systems no longer has an internet site,> > and a phone call results in "that number has been disconnected or is no> > longer in service..." Also, they no longer have e-mail (at least not at the> > address we have). Do you know if Bud Rinker will take a call for> > information and if so, how to get ahold of him? Thanks for your help.> >> > Mark Boynton> > Gilbert, AZ> >> >> > > I tracked Bud Rinker down in Santa Barbara, CA and he referred me to> > these> > > folks, as the interest had dried up and he was retired, so he gave it to> > them to> > > handle.> > > Vertical Systems> > > 34 Paradise Road> > > Santa Barbara, CA, 93105> > > e-mail at vertsys(at)west.net and a web page at> > http://www.west.net/~vertsys> > > The plans set is $75.00 plus $2.00 postage, with particular> > attention to> > > Corvair engine application.> > > Haven't tried any of this for awhile, so can not confirm that they are> > their any> > > longer.> > > Warren> > >> > > mboynton(at)excite.com wrote:> > >> > > > To all:> > > >> > > > Can any of you provide information about the article or articles in> > Sport> > > > Aviation that appeared, I believe, in the 70's, about the PSRU designed> > by> > > > Bud Rinker, using the gear reduction box from a Type 2 (bus) Volkswagon> > > > transaxle. The system is commonly referred to as a Rinker redrive or> > Rinker> > > > PSRU, and can be used to reduce prop speed on the Corvair engine.> > Vertical> > > > Systems, the outfit that markets the plans set for it, seems to have> > dropped> > > > off of the face of the earth. I've contacted the EAA library, but they> > were> > > > unable to give me any solid leads. I'm certain that either Bud Rinker> > had> > > > an article published or that someone else did, about his system.> > However,> > > > EAA is unable to do a search that far back by author name, and none of> > the> > > > titles they cited mentioned the Rinker PSRU (not directly in the title.> > I'm> > > > certain the information is there, but I can't seem to locate it. Help!> > > >> > > > Mark Boynton> > > > Gilbert, AZ> > > >> > > > _______________________________________________________> > >> >> > _______________________________________________________________________________________________________________________________________
Original Posted By: PietChat(at)aol.com
Warren,I really do appreciate the help. I'll stand by and hope for the best.Mark> Follow-up:> Got in touch with Bud's daughter, who called her Dad. He knows thatthis guy> has a project of some kind going at the local airport and is going to findhim and> see what he can do.> Bud apparently no longer has any drawings or data sheets, having soldthem to> this guy. Will keep you posted.> Warren> > Warren Shoun wrote:> > > Mark,> > I just checked: they shut down their website in December, and Eric,the> > site host, has no forwarding information for them.> > I have tried in the fast few months to recontact Bud Rinker andthere is no> > answer at the old number that I had or it is busy for 6-10 hours. Willcontinue> > to see what I can do.> > Warren> >> > mboynton(at)excite.com wrote:> >> > > Warren,> > >> > > Thanks. The kicker is that Vertical Systems no longer has an internetsite,> > > and a phone call results in "that number has been disconnected or isno> > > longer in service..." Also, they no longer have e-mail (at least notat the> > > address we have). Do you know if Bud Rinker will take a call for> > > information and if so, how to get ahold of him? Thanks for yourhelp.> > >> > > Mark Boynton> > > Gilbert, AZ> > >> > >> > > > I tracked Bud Rinker down in Santa Barbara, CA and he referredme to> > > these> > > > folks, as the interest had dried up and he was retired, so he gaveit to> > > them to> > > > handle.> > > > Vertical Systems> > > > 34 Paradise Road> > > > Santa Barbara, CA, 93105> > > > e-mail at vertsys(at)west.net and a web page at> > > http://www.west.net/~vertsys> > > > The plans set is $75.00 plus $2.00 postage, with particular> > > attention to> > > > Corvair engine application.> > > > Haven't tried any of this for awhile, so can not confirm that theyare> > > their any> > > > longer.> > > > Warren> > > >> > > > mboynton(at)excite.com wrote:> > > >> > > > > To all:> > > > >> > > > > Can any of you provide information about the article or articlesin> > > Sport> > > > > Aviation that appeared, I believe, in the 70's, about the PSRUdesigned> > > by> > > > > Bud Rinker, using the gear reduction box from a Type 2 (bus)Volkswagon> > > > > transaxle. The system is commonly referred to as a Rinker redriveor> > > Rinker> > > > > PSRU, and can be used to reduce prop speed on the Corvair engine.> > > Vertical> > > > > Systems, the outfit that markets the plans set for it, seems tohave> > > dropped> > > > > off of the face of the earth. I've contacted the EAA library, butthey> > > were> > > > > unable to give me any solid leads. I'm certain that either BudRinker> > > had> > > > > an article published or that someone else did, about his system.> > > However,> > > > > EAA is unable to do a search that far back by author name, andnone of> > > the> > > > > titles they cited mentioned the Rinker PSRU (not directly in thetitle.> > > I'm> > > > > certain the information is there, but I can't seem to locate it.Help!> > > > >> > > > > Mark Boynton> > > > > Gilbert, AZ> > > > >> > > > > _______________________________________________________> > > >> > >> > > _______________________________________________________> ________________________________________________________________________________
In a message dated 4/1/99 9:29:47 AM Central Standard Time,mboynton(at)excite.com writes:<< Subj: Help, need info Date: 4/1/99 9:29:47 AM Central Standard Time
Bob,Fantastic. Just ordered those three articles from EAA. Thanks.Mark BoyntonGilbert, AZ> In a message dated 4/1/99 9:29:47 AM Central Standard Time,> mboynton(at)excite.com writes:> > Date: 4/1/99 9:29:47 AM Central Standard Time
Have a complete copy of the arcticle here.Could give the year date etc ofthe mag. Doug
Warren......and any other interested parties. I think the mystery is solved. I cameacross some papers I'd archived a while back - a response to an e-mail Isent to Vertical Systems when they were still up and running. I did asearch on the net, by name and state, for the home phone number of theindividual who responded, and got a hit in Santa Barbara. On the off chancethat it might be the same person that responded to my e-mail, I made a calland it was. He still has the plans for the Rinker PSRU and they still areavailable. He plans on reposting on the internet some time in the future.If any of you are interested, I have the information. Warren, I may haveput you to some unnecessary running around. Please accept my apologies. Itwas just a stroke of luck that I came across that correspondance. Again,thanks for your help.Mark BoyntonGilbert, AZ> Follow-up:> Got in touch with Bud's daughter, who called her Dad. He knows thatthis guy> has a project of some kind going at the local airport and is going to findhim and> see what he can do.> Bud apparently no longer has any drawings or data sheets, having soldthem to> this guy. Will keep you posted.> Warren> > Warren Shoun wrote:> > > Mark,> > I just checked: they shut down their website in December, and Eric,the> > site host, has no forwarding information for them.> > I have tried in the fast few months to recontact Bud Rinker andthere is no> > answer at the old number that I had or it is busy for 6-10 hours. Willcontinue> > to see what I can do.> > Warren> >> > mboynton(at)excite.com wrote:> >> > > Warren,> > >> > > Thanks. The kicker is that Vertical Systems no longer has an internetsite,> > > and a phone call results in "that number has been disconnected or isno> > > longer in service..." Also, they no longer have e-mail (at least notat the> > > address we have). Do you know if Bud Rinker will take a call for> > > information and if so, how to get ahold of him? Thanks for yourhelp.> > >> > > Mark Boynton> > > Gilbert, AZ> > >> > >> > > > I tracked Bud Rinker down in Santa Barbara, CA and he referredme to> > > these> > > > folks, as the interest had dried up and he was retired, so he gaveit to> > > them to> > > > handle.> > > > Vertical Systems> > > > 34 Paradise Road> > > > Santa Barbara, CA, 93105> > > > e-mail at vertsys(at)west.net and a web page at> > > http://www.west.net/~vertsys> > > > The plans set is $75.00 plus $2.00 postage, with particular> > > attention to> > > > Corvair engine application.> > > > Haven't tried any of this for awhile, so can not confirm that theyare> > > their any> > > > longer.> > > > Warren> > > >> > > > mboynton(at)excite.com wrote:> > > >> > > > > To all:> > > > >> > > > > Can any of you provide information about the article or articlesin> > > Sport> > > > > Aviation that appeared, I believe, in the 70's, about the PSRUdesigned> > > by> > > > > Bud Rinker, using the gear reduction box from a Type 2 (bus)Volkswagon> > > > > transaxle. The system is commonly referred to as a Rinker redriveor> > > Rinker> > > > > PSRU, and can be used to reduce prop speed on the Corvair engine.> > > Vertical> > > > > Systems, the outfit that markets the plans set for it, seems tohave> > > dropped> > > > > off of the face of the earth. I've contacted the EAA library, butthey> > > were> > > > > unable to give me any solid leads. I'm certain that either BudRinker> > > had> > > > > an article published or that someone else did, about his system.> > > However,> > > > > EAA is unable to do a search that far back by author name, andnone of> > > the> > > > > titles they cited mentioned the Rinker PSRU (not directly in thetitle.> > > I'm> > > > > certain the information is there, but I can't seem to locate it.Help!> > > > >> > > > > Mark Boynton> > > > > Gilbert, AZ> > > > >> > > > > _______________________________________________________> > > >> > >> > > _______________________________________________________> ________________________________________________________________________________
Doug,Could you give me the month and year of that edition and the title of thearticle. Thanks.Mark BoyntonGilbert, AZ> Have a complete copy of the arcticle here.Could give the year date etcof> the mag.> Doug> > ----------
The article was from March 1970. Doug
Original Posted By: Doug
There used to be a internet page... got it bookmarked but when I checked itabout 4 months ago, the page was gone... Maybe the server was down, Ideleted it (not more interest for me) maybe a search will find it, if stillthere.SaludosGary Gower>To all:>>Can any of you provide information about the article or articles in Sport>Aviation that appeared, I believe, in the 70's, about the PSRU designed by>Bud Rinker, using the gear reduction box from a Type 2 (bus) Volkswagon>transaxle. The system is commonly referred to as a Rinker redrive or Rinker>PSRU, and can be used to reduce prop speed on the Corvair engine. Vertical>Systems, the outfit that markets the plans set for it, seems to have dropped>off of the face of the earth. I've contacted the EAA library, but they were>unable to give me any solid leads. I'm certain that either Bud Rinker had>an article published or that someone else did, about his system. However,>EAA is unable to do a search that far back by author name, and none of the>titles they cited mentioned the Rinker PSRU (not directly in the title. I'm>certain the information is there, but I can't seem to locate it. Help!>>Mark Boynton>Gilbert, AZ >>>_______________________________________________________>>________________________________________________________________________________
> Re: Help, need info
Original Posted By: JKend81933(at)aol.com
> To: Pietenpol Discussion > Subject: Re: Help, need info> Date: Monday, April 05, 1999 6:14 PM>MARCH 1970 SPORT AVIATION-------- Doug> >> >Can any of you provide information about the article or articles inSport> >Aviation that appeared, I believe, in the 70's, about the PSRU designedby> >Bud Rinker, using the gear reduction box from a Type 2 (bus) Volkswagon> >transaxle. The system is commonly referred to as a Rinker redrive orRinker> >PSRU, and can be used to reduce prop speed on the Corvair engine. Vertical> >Systems, the outfit that markets the plans set for it, seems to havedropped> >off of the face of the earth. I've contacted the EAA library, but theywere> >unable to give me any solid leads. I'm certain that either Bud Rinkerhad> >an article published or that someone else did, about his system. However,> >EAA is unable to do a search that far back by author name, and none ofthe> >titles they cited mentioned the Rinker PSRU (not directly in the title. I'm> >certain the information is there, but I can't seem to locate it. Help!> >> >Mark Boynton> >Gilbert, AZ > >> >> >> >> >_______________________________________________________> >> >> ________________________________________________________________________________
> > Re: Help, need info
Doug,Thanks for the help.Mark> > > To: Pietenpol Discussion > > Subject: Re: Help, need info> > Date: Monday, April 05, 1999 6:14 PM> >> > MARCH 1970 SPORT AVIATION--------> Doug> > > > > > > >> > >Can any of you provide information about the article or articles in> Sport> > >Aviation that appeared, I believe, in the 70's, about the PSRUdesigned> by> > >Bud Rinker, using the gear reduction box from a Type 2 (bus)Volkswagon> > >transaxle. The system is commonly referred to as a Rinker redrive or> Rinker> > >PSRU, and can be used to reduce prop speed on the Corvair engine. > Vertical> > >Systems, the outfit that markets the plans set for it, seems to have> dropped> > >off of the face of the earth. I've contacted the EAA library, butthey> were> > >unable to give me any solid leads. I'm certain that either Bud Rinker> had> > >an article published or that someone else did, about his system. > However,> > >EAA is unable to do a search that far back by author name, and none of> the> > >titles they cited mentioned the Rinker PSRU (not directly in the title.> I'm> > >certain the information is there, but I can't seem to locate it.Help!> > >> > >Mark Boynton> > >Gilbert, AZ > > >> > >> > >> > >> > >_______________________________________________________> > >> > >> > ________________________________________________________________________________
Hi Gary,Yep, it still is gone. However, I did finally make contact with the guy whohad the site and got the information I need. Thanks.Mark> There used to be a internet page... got it bookmarked but when I checkedit> about 4 months ago, the page was gone... Maybe the server was down, I> deleted it (not more interest for me) maybe a search will find it, ifstill> there.> > Saludos> > Gary Gower> > >To all:> >> >Can any of you provide information about the article or articles inSport> >Aviation that appeared, I believe, in the 70's, about the PSRU designedby> >Bud Rinker, using the gear reduction box from a Type 2 (bus) Volkswagon> >transaxle. The system is commonly referred to as a Rinker redrive orRinker> >PSRU, and can be used to reduce prop speed on the Corvair engine.Vertical> >Systems, the outfit that markets the plans set for it, seems to havedropped> >off of the face of the earth. I've contacted the EAA library, but theywere> >unable to give me any solid leads. I'm certain that either Bud Rinkerhad> >an article published or that someone else did, about his system.However,> >EAA is unable to do a search that far back by author name, and none ofthe> >titles they cited mentioned the Rinker PSRU (not directly in the title.I'm> >certain the information is there, but I can't seem to locate it. Help!> >> >Mark Boynton> >Gilbert, AZ > >> >> >> >> >_______________________________________________________> >> >> ________________________________________________________________________________
Your welcome,hope you can find a back issue. Doug
> Help, need info
> > To all:> > Can any of you provide information about the article or articles in Sport> Aviation that appeared, I believe, in the 70's, about the PSRU designedby> Bud Rinker, using the gear reduction box from a Type 2 (bus) Volkswagon> transaxle. The system is commonly referred to as a Rinker redrive orRinker> PSRU, and can be used to reduce prop speed on the Corvair engine. Vertical> Systems, the outfit that markets the plans set for it, seems to havedropped> off of the face of the earth. I've contacted the EAA library, but theywere> unable to give me any solid leads. I'm certain that either Bud Rinkerhad> an article published or that someone else did, about his system. However,> EAA is unable to do a search that far back by author name, and none ofthe> titles they cited mentioned the Rinker PSRU (not directly in the title. I'm> certain the information is there, but I can't seem to locate it. Help!> > Mark Boynton> Gilbert, AZ > > > > > _______________________________________________________________________________________________________________________________________
> > Help, need info
> > > > To all:> > > > Can any of you provide information about the article or articles inSport> > Aviation that appeared, I believe, in the 70's, about the PSRU designed> by> > Bud Rinker, using the gear reduction box from a Type 2 (bus) Volkswagon> > transaxle. The system is commonly referred to as a Rinker redrive or> Rinker> > PSRU, and can be used to reduce prop speed on the Corvair engine. > Vertical> > Systems, the outfit that markets the plans set for it, seems to have> dropped> > off of the face of the earth. I've contacted the EAA library, but they> were> > unable to give me any solid leads. I'm certain that either Bud Rinker> had> > an article published or that someone else did, about his system. > However,> > EAA is unable to do a search that far back by author name, and none of> the> > titles they cited mentioned the Rinker PSRU (not directly in the title.> I'm> > certain the information is there, but I can't seem to locate it. Help!> > > > Mark Boynton> > Gilbert, AZ > > > > > > > > > > _______________________________________________________________________________________________________________________________________
> Help, need info
Original Posted By: "D.J.H."
> > Help, need info
Original Posted By: Rob Hart
> Re: Help, need info
Original Posted By:> > > mboynton(at)excite.com
> > Doug,> > Could you give me the month and year of that edition and the title of the> article. Thanks.> > Mark Boynton> Gilbert, AZ> > > > Have a complete copy of the arcticle here.Could give the year date etc> of> > the mag.> > Doug> > > > ----------
> > > Help, need info
Original Posted By: kyle ray
> > > > > > To all:> > > > > > Can any of you provide information about the article or articles in> Sport> > > Aviation that appeared, I believe, in the 70's, about the PSRUdesigned> > by> > > Bud Rinker, using the gear reduction box from a Type 2 (bus)Volkswagon> > > transaxle. The system is commonly referred to as a Rinker redrive or> > Rinker> > > PSRU, and can be used to reduce prop speed on the Corvair engine. > > Vertical> > > Systems, the outfit that markets the plans set for it, seems to have> > dropped> > > off of the face of the earth. I've contacted the EAA library, butthey> > were> > > unable to give me any solid leads. I'm certain that either BudRinker> > had> > > an article published or that someone else did, about his system. > > However,> > > EAA is unable to do a search that far back by author name, and noneof> > the> > > titles they cited mentioned the Rinker PSRU (not directly in thetitle.> > > I'm> > > certain the information is there, but I can't seem to locate it. Help!> > > > > > Mark Boynton> > > Gilbert, AZ > > > > > > > > > > > > > > > _______________________________________________________> > > > > > _______________________________________________________________________________________________________________________________________
>> > Help, need info
>> >>> > To all:>> >>> > Can any of you provide information about the article or articles in>Sport>> > Aviation that appeared, I believe, in the 70's, about the PSRU designed>> by>> > Bud Rinker, using the gear reduction box from a Type 2 (bus) Volkswagon>> > transaxle. The system is commonly referred to as a Rinker redrive or>> Rinker>> > PSRU, and can be used to reduce prop speed on the Corvair engine.>> Vertical>> > Systems, the outfit that markets the plans set for it, seems to have>> dropped>> > off of the face of the earth. I've contacted the EAA library, but they>> were>> > unable to give me any solid leads. I'm certain that either Bud Rinker>> had>> > an article published or that someone else did, about his system.>> However,>> > EAA is unable to do a search that far back by author name, and none of>> the>> > titles they cited mentioned the Rinker PSRU (not directly in the title.>>> I'm>> > certain the information is there, but I can't seem to locate it. Help!>> >>> > Mark Boynton>> > Gilbert, AZ>> >>> >>> >>> >>> > _______________________________________________________>>>_______________________________________________________>________________________________________________________________________________
> > > Re: Help, need info
> > Doug,> > Thanks for the help.> > Mark> > > > > > > To: Pietenpol Discussion > > > Subject: Re: Help, need info> > > Date: Monday, April 05, 1999 6:14 PM> > >> > > > MARCH 1970 SPORT AVIATION--------> > Doug> > > > > > > > > > > > > >> > > >Can any of you provide information about the article or articles in> > Sport> > > >Aviation that appeared, I believe, in the 70's, about the PSRU> designed> > by> > > >Bud Rinker, using the gear reduction box from a Type 2 (bus)> Volkswagon> > > >transaxle. The system is commonly referred to as a Rinker redriveor> > Rinker> > > >PSRU, and can be used to reduce prop speed on the Corvair engine. > > Vertical> > > >Systems, the outfit that markets the plans set for it, seems to have> > dropped> > > >off of the face of the earth. I've contacted the EAA library, but> they> > were> > > >unable to give me any solid leads. I'm certain that either BudRinker> > had> > > >an article published or that someone else did, about his system. > > However,> > > >EAA is unable to do a search that far back by author name, and noneof> > the> > > >titles they cited mentioned the Rinker PSRU (not directly in thetitle.> > > I'm> > > >certain the information is there, but I can't seem to locate it.> Help!> > > >> > > >Mark Boynton> > > >Gilbert, AZ > > > >________________________________________________________________________________
