Pietenpol-List: Re:Welding of telescoping landing gear legs.
Original Posted By: Jim Sury
Subject: Pietenpol-List: Re:Welding of telescoping landing gear legs.>>I'm trying to weld the "t-shaped" landing gear members for the bungees-type>gears on my Grega. Per the plans. Some of you may have run into this>problem, too.>>The upper arm is .75 -.049 tubing. the lower arm is .875 - .035 tubing>(note it's ID is plenty). The upper arm is supposed to telescope (slide)>into the lower one. Small cross members are welded on both lower and upper>arms about 5 inches or so apart to form a "T" on each member. The bungees>then wrap around the T's providing a telescoping unit that ties the axle to>the bottom of the fuse (OK , sort of, this is getting too hard to>describe).>>Herein lies the problem.>>I am welding with Acetylene torch, so when I weld the T"s unto the LOWER>leg (you know the bigger one that the smaller slides into), the slag(?)>accumulates just enough on the inside to prohibit the upper leg fromsliding>freely. I'm not a bad welder so I feel like I am not putting too much heat>into the tubing. It just seems that there should be a better way.>>Is there any sort of reamer that would be wide enough to run down throughit>(kind a like Roto Rooter for homebuilts) after the welding is complete?>Could a machine shop do this.>Would it be better to wire weld this part?>I could just make it a FIXED gear Grega......>>Thanks for the help,>bert>>________________________________________________________________________________Date: Thu, 27 Jan 2000 08:57:46 -0600
Re: Pietenpol-List: Re:Welding of telescoping landing gear legs.
Original Posted By: "Gary Meadows"
Subject: Re: Pietenpol-List: Re:Welding of telescoping landing gear legs.>>Gary I don't think that the tires are the concern. I think it is the width>of the bearing area on motorcycle wheels that is the concern. The side>loading that the wheels have to endure on landings that are less than>perfect. If you never drift on landing the motorcycle wheels would be just>fine. Also the axle size will be something to consider. The axle should be>no less than 1 inch. in dia. My axle is 1 inch. But if I hadn't already had>wheels and axle I would have used 1 1/4 inch dia. axles. jas>>>>>>Jim,>>>> I read your comments on the gear with great interest. I know on yourplane>>you have the split gear and regular tires. Based on your experience would>>the motorcyle type tires be tough enough to handle the abuse?>>>> I had thought about going with straight axle/spoked wheels, but the moreI>>think about it, the better the split/ballon type tire seems to make more>>sense. Especially since I'll be feeding my plane a steady diet of hard>>surface runways.>>>>Thanks!>>Gary M.>>>>>>________________________________________________________________________________
Re: Pietenpol-List: Welding of telescoping landing gear legs.
Original Posted By: "Tim Cunningham"
Subject: Re: Pietenpol-List: Welding of telescoping landing gear legs.>>Mike,>>I agree with you on the 4-wheel drivers, my brother was almost killed by a>woman who was meesing with her kids and not looking for riders on>motorcycles. I gave up streetbikes a long time ago!>> I have seen a lot of cycle action, though. I used to race motocross whenI>was younger, and yes, those tires do take a lot of abuse, But I'd hate too>see one of my old knobbies if I hit the concrete with 1200 lbs of airplane>on one wheel in a crosswind! I also don't have tire screws or tire clampsin>this plane, I had those on my race bikes, so who knows what that bead would>do given enough pressure I wonder how well A Harley's tires would hold up>if you dropped it straight down 5 or 6 feet onto concrete? Certificated>aircraft and their tires have to sustain a 10 foot fall, I've got to wonder>if they're up to that or not>> The loads you mentioned were load imposed in a building manner, not a>sudden shock like a botched landing would be. I doubt if there is very much>impact pressure on a 150 MPH street tire. As far as side loads, if you look>at the way a motorcycle turns, there is little side load even on aroad-race>bike. To turn one of those, you have to lean the bike over, so the bulk of>the weight is still pushed straight up though the tire. Another thing, how>much tread is on the ground on cycle tires vs aircraft type tired? Grassand>nostalgia are nice, but the reality is, my plane will spend most all ofit's>life on hard-surface runways, and I like directional control after landing,>to me more rubber can only help. I also think that given a soft surface the>spoke wheels/cycle tires might be better than "regular" tires on a soft>runway, although, they'd tend to sink in worse.>> Anyway, cycle tires will probably do the job, maybe they won't. I know>Air-Hawks or Flight Customs will, and I feel like some of the 4-wheeler>style tires will, too, I'm not really worried about the spoked wheels>themselves being able to take the load, just that skinny little strip of>rubber.>> But even given all those arguments, I'm still considering the spoke>wheels/cycle tires - they just look soooo cool!>>Two more cents.>>Gary M.>>________________________________________________________________________________
Original Posted By:>> Gary Meadows
Subject: Pietenpol-List: Guys with flashers>>Mike I couldn't help commenting. I'm one of those guy's with flashers andI>and bunch of my cohorts have spent our time on bikes and many of them still>ride their Harley's. I've never had anyone go so fast that I wouldn't keep>up. Never lost a chase in my 30 years of police work. I hate to think how>many squad cars I wrecked, but everyone was caught, hospitalized if needed>and jailed. Now I fly the Piet, low and slow and I can't even keep up with>normal freeway traffic. At least there's no police brutality (the fun part>of the job) when I land. Seriously, I like the look of motorcyle wheels,>but some of the places I've landed just wouldn't do. I'll stick with my>balloon 800 x 4's.>Copinfo(at)home.com>Tim Cunningham>1117 SE 80th Street>Runnells, Iowa 50237 (515) 237-1510>----- Original Message ----->From: Mike Lund >To: >Sent: Thursday, January 27, 2000 4:06 PM>Subject: Re: Pietenpol-List: Welding of telescoping landing gear legs.>>>>>> Ah, Gary...>>>> Lets get a couple of GSXR 1100's.....Or a Yamaha's ...or just good old>fat>> boys. I'll show ya how to put side loads on tires. On gravelroads....and>> run so fast the boys with the flahsers dont even dream of keeping up.>>>> Flash foreward, wife and kids, and I am building the slowest thing in the>> sky....but give me 2 wheels agian....>>>> Old enough to know better,>> too young to care.>>>> (Dad, at 73. got an 883 sportster for his last birthday. HIS last bikewas>a>> '33 dkw )>>>> Mike>> -----Original Message-----
Original Posted By: "Mike Lund"
Jim, I read your comments on the gear with great interest. I know on your plane you have the split gear and regular tires. Based on your experience would the motorcyle type tires be tough enough to handle the abuse? I had thought about going with straight axle/spoked wheels, but the more I think about it, the better the split/ballon type tire seems to make more sense. Especially since I'll be feeding my plane a steady diet of hard surface runways.Thanks!Gary M.________________________________________________________________________________
Original Posted By: "Everett Perkins"
> I read your comments on the gear with great interest. I know on yourplane>you have the split gear and regular tires. Based on your experience would>the motorcyle type tires be tough enough to handle the abuse?I have ridden, raced, abused and beat-up motorcyles since I was 12. Sartedwith a little Honda "minni-bike" (damn, I'd like ta have that thing again;-) Low riders, Cafe racers, hogs (best I ever had was a GSXR) ... the tirescan can take it. I have never had a blow-out. The side-load theory is(*&%$.Just what do you think is happening to that tire in a 150mph curve on a600#machine with 200# of rider and 30# of fuel ????. Bends,yes..flexes...yes. blows out...not unless its defective. How boutpotholes???, road breaks???? HARD breaking???? (DONT touch that frontlever....)On the otherhand, these morons in 4 wheel vehicals that dont see arider....2 hits was enough, I quit riding, but I trust the parts completly.> I had thought about going with straight axle/spoked wheels, but the moreI>think about it, the better the split/ballon type tire seems to make more>sense. Especially since I'll be feeding my plane a steady diet of hard>surface runways.Ever seen a hard driven bike on grass???. Blacktop is what those tires weredeisgned for.I am using old honda wheels, hubs and brakes, spoked (prob old CB350 or 450)and if I hit hard enough to break a wheel, I will be to busy healing tocare.Now, overall design... I am going to use the scout-type. The last thing yawant in a taildragger is hit long grass with a cross axel.just my .02Mike>>Thanks!>Gary M.>>________________________________________________________________________________
Using motorcycle wheels is fine EXCEPT they do not have enough "dish" formuch side load. Spacing the bearings and the spoke flanges farther apartsolves the problemCy Galley - Editor, B-C Contact!(Click here to visit our Club site at http://www.bellanca-championclub.com)-----Original Message-----
Mike,I agree with you on the 4-wheel drivers, my brother was almost killed by a woman who was meesing with her kids and not looking for riders on motorcycles. I gave up streetbikes a long time ago! I have seen a lot of cycle action, though. I used to race motocross when I was younger, and yes, those tires do take a lot of abuse, But I'd hate too see one of my old knobbies if I hit the concrete with 1200 lbs of airplane on one wheel in a crosswind! I also don't have tire screws or tire clamps in this plane, I had those on my race bikes, so who knows what that bead would do given enough pressure I wonder how well A Harley's tires would hold up if you dropped it straight down 5 or 6 feet onto concrete? Certificated aircraft and their tires have to sustain a 10 foot fall, I've got to wonder if they're up to that or not The loads you mentioned were load imposed in a building manner, not a sudden shock like a botched landing would be. I doubt if there is very much impact pressure on a 150 MPH street tire. As far as side loads, if you look at the way a motorcycle turns, there is little side load even on a road-race bike. To turn one of those, you have to lean the bike over, so the bulk of the weight is still pushed straight up though the tire. Another thing, how much tread is on the ground on cycle tires vs aircraft type tired? Grass and nostalgia are nice, but the reality is, my plane will spend most all of it's life on hard-surface runways, and I like directional control after landing, to me more rubber can only help. I also think that given a soft surface the spoke wheels/cycle tires might be better than "regular" tires on a soft runway, although, they'd tend to sink in worse. Anyway, cycle tires will probably do the job, maybe they won't. I know Air-Hawks or Flight Customs will, and I feel like some of the 4-wheeler style tires will, too, I'm not really worried about the spoked wheels themselves being able to take the load, just that skinny little strip of rubber. But even given all those arguments, I'm still considering the spoke wheels/cycle tires - they just look soooo cool!Two more cents.Gary M.________________________________________________________________________________
Ah, Gary...Lets get a couple of GSXR 1100's.....Or a Yamaha's ...or just good old fatboys. I'll show ya how to put side loads on tires. On gravel roads....andrun so fast the boys with the flahsers dont even dream of keeping up.Flash foreward, wife and kids, and I am building the slowest thing in thesky....but give me 2 wheels agian....Old enough to know better,too young to care.(Dad, at 73. got an 883 sportster for his last birthday. HIS last bike was a'33 dkw )Mike-----Original Message-----
> Subject: Re: Pietenpol-List: Welding of telescoping landing gear legs.>>> > >> >Mike,> >> >I agree with you on the 4-wheel drivers, my brother was almost killed bya> >woman who was meesing with her kids and not looking for riders on> >motorcycles. I gave up streetbikes a long time ago!> >> > I have seen a lot of cycle action, though. I used to race motocrosswhen> I> >was younger, and yes, those tires do take a lot of abuse, But I'd hatetoo> >see one of my old knobbies if I hit the concrete with 1200 lbs ofairplane> >on one wheel in a crosswind! I also don't have tire screws or tire clamps> in> >this plane, I had those on my race bikes, so who knows what that beadwould> >do given enough pressure I wonder how well A Harley's tires would holdup> >if you dropped it straight down 5 or 6 feet onto concrete? Certificated> >aircraft and their tires have to sustain a 10 foot fall, I've got towonder> >if they're up to that or not> >> > The loads you mentioned were load imposed in a building manner, not a> >sudden shock like a botched landing would be. I doubt if there is verymuch> >impact pressure on a 150 MPH street tire. As far as side loads, if youlook> >at the way a motorcycle turns, there is little side load even on a> road-race> >bike. To turn one of those, you have to lean the bike over, so the bulkof> >the weight is still pushed straight up though the tire. Another thing,how> >much tread is on the ground on cycle tires vs aircraft type tired? Grass> and> >nostalgia are nice, but the reality is, my plane will spend most all of> it's> >life on hard-surface runways, and I like directional control afterlanding,> >to me more rubber can only help. I also think that given a soft surfacethe> >spoke wheels/cycle tires might be better than "regular" tires on a soft> >runway, although, they'd tend to sink in worse.> >> > Anyway, cycle tires will probably do the job, maybe they won't. I know> >Air-Hawks or Flight Customs will, and I feel like some of the 4-wheeler> >style tires will, too, I'm not really worried about the spoked wheels> >themselves being able to take the load, just that skinny little strip of> >rubber.> >> > But even given all those arguments, I'm still considering the spoke> >wheels/cycle tires - they just look soooo cool!> >> >Two more cents.> >> >Gary M.> >> >>>________________________________________________________________________________Date: Thu, 27 Jan 2000 16:25:04 -0700 (MST)
>> Subject: Re: Pietenpol-List: Welding of telescoping landing gear legs.>>>>>> >> >>> >Mike,>> >>> >I agree with you on the 4-wheel drivers, my brother was almost killed by>a>> >woman who was meesing with her kids and not looking for riders on>> >motorcycles. I gave up streetbikes a long time ago!>> >>> > I have seen a lot of cycle action, though. I used to race motocross>when>> I>> >was younger, and yes, those tires do take a lot of abuse, But I'd hate>too>> >see one of my old knobbies if I hit the concrete with 1200 lbs of>airplane>> >on one wheel in a crosswind! I also don't have tire screws or tireclamps>> in>> >this plane, I had those on my race bikes, so who knows what that bead>would>> >do given enough pressure I wonder how well A Harley's tires would hold>up>> >if you dropped it straight down 5 or 6 feet onto concrete? Certificated>> >aircraft and their tires have to sustain a 10 foot fall, I've got to>wonder>> >if they're up to that or not>> >>> > The loads you mentioned were load imposed in a building manner, not a>> >sudden shock like a botched landing would be. I doubt if there is very>much>> >impact pressure on a 150 MPH street tire. As far as side loads, if you>look>> >at the way a motorcycle turns, there is little side load even on a>> road-race>> >bike. To turn one of those, you have to lean the bike over, so the bulk>of>> >the weight is still pushed straight up though the tire. Another thing,>how>> >much tread is on the ground on cycle tires vs aircraft type tired? Grass>> and>> >nostalgia are nice, but the reality is, my plane will spend most all of>> it's>> >life on hard-surface runways, and I like directional control after>landing,>> >to me more rubber can only help. I also think that given a soft surface>the>> >spoke wheels/cycle tires might be better than "regular" tires on a soft>> >runway, although, they'd tend to sink in worse.>> >>> > Anyway, cycle tires will probably do the job, maybe they won't. I know>> >Air-Hawks or Flight Customs will, and I feel like some of the 4-wheeler>> >style tires will, too, I'm not really worried about the spoked wheels>> >themselves being able to take the load, just that skinny little strip of>> >rubber.>> >>> > But even given all those arguments, I'm still considering the spoke>> >wheels/cycle tires - they just look soooo cool!>> >>> >Two more cents.>> >>> >Gary M.>> >>> >>>>>>>________________________________________________________________________________
Original Posted By:> Ken Beanlands
> > Subject: Re: Pietenpol-List: Welding of telescoping landing gear legs.> >> >> > > > >> > >Mike,> > >> > >I agree with you on the 4-wheel drivers, my brother was almost killed by> a> > >woman who was meesing with her kids and not looking for riders on> > >motorcycles. I gave up streetbikes a long time ago!> > >> > > I have seen a lot of cycle action, though. I used to race motocross> when> > I> > >was younger, and yes, those tires do take a lot of abuse, But I'd hate> too> > >see one of my old knobbies if I hit the concrete with 1200 lbs of> airplane> > >on one wheel in a crosswind! I also don't have tire screws or tire clamps> > in> > >this plane, I had those on my race bikes, so who knows what that bead> would> > >do given enough pressure I wonder how well A Harley's tires would hold> up> > >if you dropped it straight down 5 or 6 feet onto concrete? Certificated> > >aircraft and their tires have to sustain a 10 foot fall, I've got to> wonder> > >if they're up to that or not> > >> > > The loads you mentioned were load imposed in a building manner, not a> > >sudden shock like a botched landing would be. I doubt if there is very> much> > >impact pressure on a 150 MPH street tire. As far as side loads, if you> look> > >at the way a motorcycle turns, there is little side load even on a> > road-race> > >bike. To turn one of those, you have to lean the bike over, so the bulk> of> > >the weight is still pushed straight up though the tire. Another thing,> how> > >much tread is on the ground on cycle tires vs aircraft type tired? Grass> > and> > >nostalgia are nice, but the reality is, my plane will spend most all of> > it's> > >life on hard-surface runways, and I like directional control after> landing,> > >to me more rubber can only help. I also think that given a soft surface> the> > >spoke wheels/cycle tires might be better than "regular" tires on a soft> > >runway, although, they'd tend to sink in worse.> > >> > > Anyway, cycle tires will probably do the job, maybe they won't. I know> > >Air-Hawks or Flight Customs will, and I feel like some of the 4-wheeler> > >style tires will, too, I'm not really worried about the spoked wheels> > >themselves being able to take the load, just that skinny little strip of> > >rubber.> > >> > > But even given all those arguments, I'm still considering the spoke> > >wheels/cycle tires - they just look soooo cool!> > >> > >Two more cents.> > >> > >Gary M.> > >> > >> >> >>
