Original Posted By: "SAM & JAN MARINUCCI"
Subject: Re: Pietenpol-List: Lift Struts>>Warren:>Thank you very much! Have you heard of using round tubing and glueing>something like wood to the trailing side and making yer own streamlined>tubine??>>Steve>>writes:>> >> >> >> Got to>> http://www.sky-tek.com/struts.html>> >> and smile again!>> Cheers,>> Warren>> >> >> >> >> >>Steve W GN-1 builder>IHA #6>>________________________________________________________________________________
Pietenpol-List: Turtledeck Stringers
Original Posted By: "Doug"
Subject: Pietenpol-List: Lift Struts>>>Got to>http://www.sky-tek.com/struts.html>>and smile again!>Cheers,>Warren>>________________________________________________________________________________
What is everybody using for thier stringers. 1/4" x 1" seems a bit heafty. Iwas thinking along the lines of 3/4" x 1/4" ceder.MikeAirplanes dont fly on gas, they fly on money.The more money you throw at them,the faster they fly.IHA 110________________________________________________________________________________
Original Posted By: "Domenico Bellissimo"
Subject: Re: Pietenpol-List: Lift StrutsWarren:Thank you very much! Have you heard of using round tubing and glueingsomething like wood to the trailing side and making yer own streamlinedtubine??Stevewrites:> > > > Got to> http://www.sky-tek.com/struts.html> > and smile again!> Cheers,> Warren> > > > > Steve W GN-1 builderIHA #6________________________________________________________________________________
Re: Pietenpol-List: Turtledeck Stringers
That's what I used 1/4 X 3/4. It's a little week in the middle, and youcertainly can't sit on the Turtle deck just aft of the pilot's seat. Tocircumvent this problem Brian Kenney suggested I use 1/6 ply glued to thetop of the stringers and sandwich this with light corrugated cardboard. Boydid this ever stiffen that area. Sitting was no problemo after that. I tookthe cardboard all the way to the first bay aft of the pilots' seat. I closedthe end. Added a lockable door on the pilots' seat back and used thecompartment for my goggles, gloves or anything else I wanted to lock away.Brian's suggestion was a result of a little damage from something inside theglove box, that hit the fabric on a hard landing. This sure works for me.Regards,Domenic________________________________________________________________________________Date: Fri, 28 Jan 2000 15:47:37 -0800
I used the stuts from Sky-tek, very economical. Doug Hunt-----Original Message-----
Just a thought.........are aluminum lift struts okay to use instead of 4130steel struts? Sam-----Original Message-----
Original Posted By: Mike Lund
Mike,i used the 1/4x3/4,and just behind the pilot,i wrapped a fairly widestip of 3/32 okume(spelling?)marine mahogany,you can sit on it witout even acreek,will send you a pic directly. Doug Hunt.....-----Original Message-----
