pietenpol-list(at)matronics.com> Pietenpol-List: Passenger seatbelt a
Hi BenThanks for the picture. How did you safety the lower cabane mounting bolts?CheersRob HartOne of four builders in Perth, Western Australiapietenpol-list(at)matronics.com> Subject: Pietenpol-List: Passenger seatbelt aarvet > > I got this idea from the UK website. The rear mounts bolt through the > upper longeron and an extra cross piece I glued in. The forward end is > mounted to the through bolts for the cabanes. I turned down a piece of > steel rod to fit inside the tube, welded it in place, then drilled and > tapped it for the bolt.. It doesn't weigh much, and gets the shoulder > harness up to shoulder level. I've seen the results of harness failures > in a friend at our local airport, and it isn't pretty. Unfortunately, > its impossible to test it, (I hope to never have to test it) but this > seems to take advantage of the structure available for mounting.> > http://www.mykitplane.com/Planes/buildL ... ==========> > > _________________________________________________________________It's simple! Sell your car for just $30 at CarPoint.com.aue%2Ecom%2Fcgi%2Dbin%2Fa%2Fci%5F450304%2Fet%5F2%2Fcg%5F801459%2Fpi%5F1004813%2Fai%5F859641&_t=762955845&_r=tig_OCT07&_m=EXT________________________________________________________________________________Date: Sat, 12 Apr 2008 22:08:27 -0400
Re: Pietenpol-List: Passenger seatbelt attach points- how I did it]
Original Posted By:> > bcharvet(at)bellsouth.net
