Original Posted By: Dan Yocum
Subject: Re: Pietenpol-List: Fuselage ConstructionMark for what its worth, and that may be very little, I have chosen to hold off closing in the sides for fear of losing important access and painting myself into a corner. Once i get all the goodies in and installed to my liking I will close in the sides. I think access plays a big part in the construction process and I see no need to limit that and such a early stage.Juss how I'm doing it! I like to keep my options open as long as possible, but then again at my age forget lots of stuff and don't want to be forced to remove a glued in panel , then be faced with the ugly job of removing it afterwards.JohnIn a message dated 9/21/2010 11:52:09 A.M. Eastern Daylight Time, rmueller23(at)gmail.com writes:Hi Mark, Congrats on progressing to the fuselage. For the right fuselage side, what about just gluing the butt joints? Let those joints dry and then carefully remove the fuselage from the jig, flip it over on the table, and glue the gussets on....RyanOn Tue, Sep 21, 2010 at 9:54 AM, K5YAC wrote:--> Pietenpol-List message posted by: "K5YAC" I am currently assembling my fuselage sides, but I am uncertain as to the best approach. I have constructed a jig directly on my workbench table top, which I used to assemble and glue my left fuselage side (gussets on inside right). I planned to use the Pietenpol method of tracing that assemblyon to my 1/8" plywood in order to attach that to the next assembly since I obviously can't install the gussets to the side laying on the table. This would be my right side assembly (plywood sheet on the right side). While this method seems to make good sense to me, I've got a couple of questions/observations...1. Will having the plywood sheet on the right side make future processes more difficult? Reasons that I shouldn't do it this way?2. I notice that many builders have a completed skeletal structure with no plywood sheet on the outside of the fuse (see Jack's photo below). How did you accomplish this? I would like to use the same jig for both halves inorder to make exact copies for each assembly, but I can't figure out how else (or how better), to accomplish this, other than the way Bernard spoke about (tracing plywood sheet and applying it to second assembly).I hope that what I am asking makes sense, and that someone might be able to shed some light on the matter.--------Mark ChouinardWings and Center Section framed up - Working on EmpannageRead this topic online here:_http://forums.matronics.com/viewtopic.php?p=313210#313210_ (
http://forums.matronics.com/viewtopic.p ... 210#313210) Attachments:_http://forums.matronics.com//files/new_piet_007_450x600_260.jpg_ (
http://forums.matronics.com//files/new_ ... 00_260.jpg) ==========st" target="_blank">
http://www.matronics.com/Navigator?Piet ... ========le, List Admin.="_blank">
http://www.matronics.com/contribution== ... npol-List) (
http://www.matronics.com/contribution) ________________________________________________________________________________Date: Tue, 21 Sep 2010 11:53:24 -0500
