Pietenpol-List: Standard fuselage/corvair motor
Re: Pietenpol-List: Standard fuselage/corvair motor
Original Posted By: james theissen
=0A=0A=0A =0A =0A=0A=0A=0A=0A=0A=0AMichael, =0A=0A =C2- =0A=0AI would be seriously concerned about =9Cfree floating=9D=0Aa fairing on the axle.=C2- That area is subjected to some major prop blast and I=0Awould be very worried to failures due to the constant vibrations. =0A=0A =C2- =0A=0ADouwe =0A=0A=0A=0A=0A=0A=0A=0A=0A________________________________________________________________________________Date: Tue, 3 May 2011 14:06:17 -0400Subject: Re: Pietenpol-List: Standard fuselage/corvair motor
Original Posted By: "heavyliftpilot"
Very nice.....!--------Jake Schultz - curator,Newport Way Air Museum (OK, it's just my home)Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Standard fuselage/corvair motor
Original Posted By: Dan Yocum
Hi, I'm looking at a steel tube fuselage for sale, but it's the standard length.Does anyone know if that will work with a corvair motor (weight and balance)?Thanks. jamesRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Standard fuselage/corvair motor
You'll have to make the engine mount longer. Dan-- Dan Yocumyocum137(at)gmail.com"I fly because it releases my mind from the tyranny of petty things."On May 3, 2011, at 4:51 AM, "heavyliftpilot" wrote:> > Hi, I'm looking at a steel tube fuselage for sale, but it's the standard length.Does anyone know if that will work with a corvair motor (weight and balance)?Thanks. james> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 724#338724> > > > > > > > > > ________________________________________________________________________________Date: Tue, 3 May 2011 09:10:16 -0400Subject: Re: Pietenpol-List: Standard fuselage/corvair motor
Hey Michael,As mentioned, my axle fairing (Jenny style) is fabricated from aluminumsheet. Ply should work fine (did in World War I?)I attached mine by welding three sets of tabs on the spreader bars to whichI bolted three aluminum "ribs" to which the rest of the structure rivets to.The axle sits in a trough covered with a hinged flap, held down by somelight springs so the axle can come up to it's limit by just lifting the trapdoor. During normal axle movement, I don't anticipate it hitting the doorat all, but we'll see.The entire assembly weighs a bit under 3lbs and should reduce the drag fromthe axle and spreader bars, and might provide a couple pounds of lift. Allthat being said, I really did it because I thought it looked cool and I feltthe weigh penalty was likely canceled out by the drag reduction.Can send pics if you likeDouwe________________________________________________________________________________Date: Tue, 3 May 2011 09:12:30 -0600Subject: Re: Pietenpol-List: Standard fuselage/corvair motor
Re: Pietenpol-List: axle fairing
Subject: Re: Pietenpol-List: axle fairing
Hi James,Confusion is a normal state of affairs on this list - if you doubt it start looking through the archive ;). Seriously, though, the answer to your question is "it depends". Mike Cuy has an A-65 on a standard length wood fuselage, there are people with model A's on long fuselages, corvairs on long and short fuse's, just about any combination you can think of. It really depends on how YOU build the plane. I'm sure that helps :).Kip GardnerOn May 3, 2011, at 11:23 AM, james theissen wrote:> >>> OK, now i'm really confused. I have a set of plans at the house that> i'll have to look at closely tonight. thanks, james>> On Tue, May 3, 2011 at 11:12 AM, Rick Holland > wrote:>> I would say the opposite would be true, the long fuselage is 9 >> inches longer>> at the tail plus the rear seat is a couple inches further back >> giving it the>> greatest aft CG problems.>>>> rick>>>> On Tue, May 3, 2011 at 7:10 AM, james theissen > >>> wrote:>>>>>> >>>>>> Hi Dan, do you know about how much longer? And could i also move>>> things fwd, like the battery, etc? thanks, james>>>>>> On Tue, May 3, 2011 at 7:34 AM, Dan Yocum >>> wrote:>>>> >>>>>>>> You'll have to make the engine mount longer.>>>>>>>> Dan>>>>>>>> -->>>> Dan Yocum>>>> yocum137(at)gmail.com>>>> "I fly because it releases my mind from the tyranny of petty >>>> things.">>>>>>>> On May 3, 2011, at 4:51 AM, "heavyliftpilot" >>> >>>>> wrote:>>>>>>>>> >>>>>>>>>> Hi, I'm looking at a steel tube fuselage for sale, but it's the>>>>> standard length. Does anyone know if that will work with a >>>>> corvair motor>>>>> (weight and balance)? Thanks. james>>>>>>>>>>>>>>>>>>>>>>>>> Read this topic online here:>>>>>>>>>> http://forums.matronics.com/viewtopic.p ... 724#338724>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ==========>>> st" target="_blank">http://www.matronics.com/Navigator?Pietenpol- >>> List>>> ==========>>> http://forums.matronics.com>>> ==========>>> le, List Admin.>>> ="_blank">http://www.matronics.com/contribution>>> ==========>>>>>>>>>>>>>>>>> -->> Rick Holland>> Castle Rock, Colorado>> NX6819Z>>>> "Logic is a wreath of pretty flowers, that smell bad">>>>>>>>________________________________________________________________________________Date: Tue, 03 May 2011 11:52:56 -0500
Original Posted By: shad bell
Re: Pietenpol-List: Re: Standard fuselage/corvair motor
Well Said DaveI have nothing to add to that, except that Jon Goldenbaum at Stits Poly Fiber is going to donate 90' of fabric that will be offered seperatly.Dick N.----- Original Message -----
Re: Pietenpol-List: aluminum lower strut fitting
Original Posted By: bender
Hey Jeff,I am sure this will work. Those structural rivets will be just fine. With four struts the load is spread out. I would maybe tighten-down on the lower strut attach bolts so there is no movement; no chance of elongation of aluminum holes.Dan HelsperPuryear, TN-----Original Message-----
Pete Bowers added floats to his fly-baby and ended up upside-down in lake Washington(pilot error I believe... don't quote me) I knew.Pete and sure wish he wasstill around to share Pietenpol stories...... So glad all of you are part of this grand group of people...[/list]--------Jake Schultz - curator,Newport Way Air Museum (OK, it's just my home)Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 4 May 2011 05:39:41 -0400Subject: Re: Pietenpol-List: Re: Standard fuselage/corvair motor
